2007 jaguar xj speaker upgrade
Old 01-14-2019, 11:26 PM
Erick Burlya's Avatar
Default 2007 jaguar xj speaker upgrade
Looking to upgrade my stock speakers. Does anyone know speaker sizes? And if i can just do a direct plug in or would i have to do custom wireing?
Old 01-15-2019, 04:31 AM
EsRay's Avatar
Old 01-15-2019, 05:32 AM
Received 4,435 Likes on 2,421 Posts
The mounting flanges of the factory bass speakers in the X350 XJ are the same dimensions as the X-Type, the X250 XF, and the X150 XK.
So if you get a speaker mounting ring for any of those models it will suit the X350 XJ
The factory bass speakers are 165mm size, so an aftermarket 6.5" will fit, if you have a suitable adaptor ring.
The factory bass speakers are 2 ohm impedence.
Look at these as an example
https://www.ebay.ie/itm/Jaguar-Xf-Ca...-/142501862507
https://www.ebay.co.uk/itm/Jaguar-XF...-/371318169079
Amazon Amazon
If you want a solution where you aren't cutting the factory wiring to fit aftermarket speakers, I have these adaptor harness
https://www.jaguarforums.com/forum/p...7/#post1791039
The factory speakers in the Alpine branded system are "not bad" actually, if you have the low-spec audio (no sub) then the door speakers are pretty crummy.
Old 01-15-2019, 09:20 AM
Sean W's Avatar
Received 4,164 Likes on 2,334 Posts
EsRay, the link appears to be broken.
EsRay (01-16-2019)
Old 01-16-2019, 04:50 AM
EsRay's Avatar
Old 01-16-2019, 07:20 AM
Partick the Cat's Avatar
Still getting 'No match'
EsRay (01-16-2019)
Old 01-16-2019, 07:40 AM
EsRay's Avatar
Sean, Partick - Thanks for your posts - I have no idea what the problem is; doesn't matter anyway - Cambo appears to have answered his question satisfactorily. I just typed Speakers and Upgrade into our forum's search engine (and pasted the address; it worked when I tested it?) and of course there were reams of pages of good advice available to the Poster!
Hopefully he will do a search himself because he may need to know about how our infotainment system needs to utilise a fibre optic connection if he wants to be able to use the car controls and screen?
Sean W (01-16-2019)
multistrada74
06-29-2015 03:50 PM
XxSlowpokexX
02-25-2015 12:40 PM
Goldlion
01-22-2011 01:22 AM
Michal
Audio/Visual Electronics
06-25-2010 03:10 PM
jya
03-01-2010 04:55 PM
Quick Reply: 2007 jaguar xj speaker upgrade
