2008 XJR Won't start after Winter storage
2008 XJR Out of Winter storage.
Battery disconnected and Trickle charged over Winter. Reads 100% Charge.
Battery reconnected and when Jag is started continuous CLICKING occurs with all Dash lights and everything else on.
Never ever happened before!
Anyone know whats going on?
Received 2,255 Likes
If a battery is dead it can charge up to its max (it's dead max) but is actually holding almost no charge.
That's why they load test them to find out.
You can approximate that by putting a heavy load on (engine off, heated everything on, headlights on etc) and check voltage at battery after a few mins.
Old thread, but another thought for future reference: battery terminals/clamps have built up corrosion. Often nearly invisible, you can disconnect the clamps and it will look fine, but it is not.
Roughen up the clamp faces and the terminals with a wire brush or sandpaper. The corrosion creates a barrier between the clamp and terminal, resulting in a battery not charging sufficiently, but it can take quite some time before it becomes apparent.
Our hot and humid weather in the islands means this is an exceptionally common problem, and many people replace batteries needlessly.
