Auxiliary Coolant Pump Bosch part number?
Can anyone tell me what the Bosch part number is that is stamped on the electric auxiliary coolant pump that's mounted by the radiator? I can only read the first couple sets of numbers: 0 392 020 ???. I've done a search, and it looks like the last 3 numbers could be 024, 039 or 044. The pumps look identical minus the mounting bracked to the pump that's on my XJR, and it can be purchased for about $85 - quite a bit cheaper than what I've seen online for the Jag part. It looks like I could slide the old Bosch pump out of the mounting bracket, and slip this one in.
I got that information at home since I replaced mine last weekend. If you do not get a reply back by tonight, I will post back.
One thing to remember is that there is the auxiliary pump and then there is the super charge coolant pump. The latter is a bit bigger and they both sit in the same vicinity, near the right hand side of the radiator (passenger side). |
2 Attachment(s)
I didn't realize they were in the same vacinity. My supplier sent me a picture of 2 different pumps he had - I'm guessing one is the S/C and the other is for the heater. I'm guessing the one on the right is the auxiliary pump I need?
Yes the one on the right is the aux pump (Bosch)
Excellent photo here: https://www.jaguarforums.com/forum/x...-108987/page2/ |
2 Attachment(s)
Originally Posted by QuikCat
(Post 899982)
0 392 020 071 https://www.jaguarforums.com/forum/a...ine=1391046787 |
(Post 900201)
Can you slide the mounting bracket off of the pump? The pump looks like this one. I wonder what the difference is between the various numbers? Plug/receptical looks the same.
I found this link if it helps anyone: JCNA Forums - Jaguar Clubs of North America
But I'll probably just bite the bullet and get a new one. http://rcm-na.amazon-adsystem.com/e/...ins=B004JPZ46M |
(Post 900466)
Originally Posted by hunter34
(Post 900567)
