Can anybody with Halogen headlamps confirm this
If you have halogen headlamps and you please check the lighting stalk on the steering column.
Can you check the stalk has the Auto position and beyond that the 3 notches for delay. If you do can you switch to the delay settings and check you get a delay message in the message center. Each position show a different delay time in the message center. We are tying to confirm the delay function in the cars in fitted with halogen as opposed to HID. It appears that there is only one stalk part number indicating all models have the same. However we suspect the 3 delay positions on cars fitted with halogen lamps = the auto position If you halogens and can switch to delay for us please post the text you get in the message center or if you get no message please post you get no messages. Thanks in advance for the help. Cheers 34by151 & Cambo |
Mine is with halogens and it has the delay positions. Each rotation gives respective message - 10 sec delay, 30 sec delay and third I have never used :)
Thanks that is what I was expecting.
Cheers 34by151 |
