Car tries to pull away at lights with foot on brake?
Received 2,255 Likes
This sounds similar to 'the lurch' experienced on 2003-4 S-types. Well documented on this site.
EsRay (03-10-2018)
However, I did previously (for a time) have a P0783 fault code; I followed the steps in the DTC guide and it went away.....
EsRay (03-11-2018)
I get a slight but noticable dip at the rear of the car when at a junction or lights when - keeping the transmission in Drive and having engaged the parking brake - I take my foot off the footbrake.
It also happens if I'm waiting with parking brake on and the transmission in Neutral when I move the selector to Drive but don't let the parking brake off.
I think that's normal. If that's what you're getting and it seems to be too much the I would suggest you check the bushes in the upper and lower wishbones in the rear suspension.
EsRay (03-11-2018)
EsRay (03-11-2018)
Dear Forum,
Just to end this post the problem was a 'Drum'? in the gearbox that was cracked nearly in two. When the trans got hot, the crack expanded, leaked oil and locked the third (I think) gear up. This intermittent 'seize-up' was also what caused the billowing grey/white smoke out of my exhaust! I must admit, I still do not understand why a fault in the gearbox should cause smoke from the exhaust - But since the problem has gone away, perhaps I shouldn't care?
Samilcar (08-21-2020)
What you experienced was actually a defect in the design, and I would hope that Jaguar corrected this on the later models as this was definitely a safety issue. When applying the brake, tilt your right foot slightly to the left so as to avoid contact with the accelerator. If using a floor mat, the mat would have to be trimmed a bit in the area next to the accelerator, or omitted altogether.
EsRay (05-01-2018)
moonpetal38
01-20-2012 07:16 PM
rivs
11-20-2007 05:51 AM
