Door locks
Can not lock driver's door with remote transmitter. All other doors lock. Tried both one stage and two-stage approaches. Is this a programming issue or is this new Jag owner missing something. Manual not helpful.
More than likely needs a latch assy.
Door Locks Issue
Originally Posted by laketime
(Post 1067953)
If you are not familiar with the car I would find a good shop to relace it for you. You can find a shop in your area by searching the regional forum.
It's possible that a microswitch in the actuator has failed.
Locks are available used on e bay or you can buy a new one from a dealer. Locks are handed so you need to get the right one. Passenger door locks are not the same as driver door lock. If you decide to repair yourself I can post pictures which will help. |
I just replaced my rear passenger door one did the front passenger one 6 months ago
I got a brand new one online If you look online you will find the one you need cheaper than a dealer if you search its not a real biggie to install although I took it my local jaguar indie he did that and the headlight switch at the same time while I waited and 237 for the labour |
Driver's door lock
Originally Posted by meirion1
(Post 1069299)
(Post 1069127)
Originally Posted by staggerlee51
(Post 1072900)
Thanks. Seen many references to Don's Jaguar Service, Flemington, NJ. Might give try on this small job in order to test waters.
I bought mine from this guyGROWLER PARTS - X350, XF, X351 & F Type scroll down the page you will see the lock/actuators
Guys name is Kevan nice guy and shipping wasn't bad either considering I live in Australia |
Originally Posted by Anxious Jim
(Post 1074129)
Stagger - that's exactly the condition I had last winter. Like Meirion said, the actuator had failed. I ordered a new one from Gaudin jaguar & replaced it myself. Not extremely difficult,but not extremely easy either.
Will take look see, Doc. Nice to see what I'm dealing with. Thanks.
(Post 1074129)
Door lock actuator replacement
meirion1,
Can you post your pictures on replacing the actuator? My 2008 XJ8 driver's side just stopped working. I can lock/unlock with the key, but the fob only locks all the other doors and the small lock inside remains open. Thanks, Jim |
When an actuator fails what normally happens is the electronics thinks the
door is locked and if you open door manually with the handle the alarm goes off. Place key in ign. to stop alarm. You will need to remove door interior liner first and there are plastic clips around the perimeter-use something like a blunt chisel (maybe cover in duct tape to prevent damage) to lever each clip off. You will need to use some force but take care not to break plastic clips. NB there is a screw behind the chrome handle (covered by a round cap) ,and at the bottom of the liner (underneath). Remove black plastic moisture barrier and unplug two electric plugs from actuator Not that easy because of clips and you can't see what you are doing. Detach actuator from outer handle by seperating plastic clip on steel rod then remove screws holding actuator. Photos will not upload. Please PM me for photos via e mail. |
