Error Message "Cruise Not Available"
I had a smog check today and as soon as I pulled out of the parking lot I got a "Cruise Not Available" error message. They had the car on a dynamometer during the test so that may have something to do with it. Anyway, I pulled over and shut the car off for a few minutes. I started it back up and the error message was gone. The only other time I have ever had this displayed was when I had a weak battery. The issue never returned after I installed a new battery.
Anyone else experienced this? Any suggestions?
That's great XJL!
I wish the same had worked for me! Have you taken a test drive to confirm that your cruise control works and the error message doesn't return?
Out of curiosity, what brand of new battery did you install?
Cheers,
Don
I will test it tomorrow. I got the Duralast Gold Battery, Model H8-DLG, from Autozone for $150. Fits perfectly. I have it on a trickle charger overnight to make sure it's fully charged.
Most times i have seen this issue it is only a low voltage fault. It can just be as simple as a too much of a drop on cranking of voltage to pop the message, seldom a true fault unless you have a xtype, these are notorious for this message and a vacuum leak.
Same battery I installed. Made by Johnson Controls and with better specs than the original Varta that came with the car.
Cheers,
Don
The previous battery I installed 2 1/2 years ago was an Interstate Megatron + which is supposed to last 6 years. Although I drive the car almost daily, I only travel a 6-8 miles on surface streets so this may have been part of the problem. Does the car have to travel at highway speeds to maximize the battery charging by the alternator?
or put the car on a battery tender overnight every now and then to maintain capacity
I pretty much think it's battery related as well. When my car gets the problem with the EPB then it's a sure sign to go battery shopping. That's what happened to the S-Type I had. The EPB started acting up so I made a quick trip to Pep Boys to pick up a Bosch battery.
My update: installed a new battery and no messages anymore. I was also getting DSC not available so I took the hint and got the new battery.
The only issue I need to work on now is getting rid of the water spots on the paint. I may have to wait until a nice day to work on that task.
I know everyone has their favorites when it comes to car care products so this is only a suggestion. To truly enhance your paint while preparing it for wax, often a polish is your best bet (I am one of those guys that detail my car 3x a week, you know the type.
The Meguiar's Ultimate Polish and wax are two very good products, though strangely the ultimate wax does not thrill me with its "Thin Coat" technology. It may be the height of paint care science, but I don't like the way it feels literally like you put nothing on the car. Some may love it, I am not a fan. Going forward if you always polish before waxing, you will be amazed at how much it steps up the look if your car.
rominempire
28
Oct 8, 2020 10:39 AM
Collector1
Sep 28, 2015 03:52 AM
