Fuel Pump Voltage, XJR
Anybody know what voltage is applied to the fuel pumps for an XJR?
Is is constant? I know that the pumps are variable speed and controlled using a PWM signal from the REM and additional fuel pump module for the XJRs second pump. |
Originally Posted by paddyx350
(Post 2067840)
There will be pin out tests in one of the manuals but I can't tell you exactly where.
These should quote voltages. |
The pin point tests don't give an expected voltage
I'm going to back probe with the engine running and see what I get for the left and right hand side pumps I'm doing the pin point tests now for the wiring between the ECM and the REM and Pump Module 2 but have come across the 5 point torx on the ECM connector, so will have to get one of these before proceeding any further. |
