Jaguar Forums - Jaguar Enthusiasts Forum (https://www.jaguarforums.com/forum/)
-   XJ XJ6 / XJ8 / XJR ( X350 & X358 ) (https://www.jaguarforums.com/forum/xj-xj6-xj8-xjr-x350-x358-28/)
-   -   Gas tank cover won't open...Help (https://www.jaguarforums.com/forum/xj-xj6-xj8-xjr-x350-x358-28/gas-tank-cover-wont-open-help-61543/)
Arbus Oct 1, 2011 02:04 PM
I recently brought my 2004 Xj8 in to have new brakes. I have noticed that when it rains my keyless remote doesn't work until about 3 days after. Today, I went to get gas, and the gas cover won't open! Could something have gone wrong when they put the front brakes, or are these problems be totally unrelated? My mechanic won't be open until Monday. Thank you in advance for your help.
QuadManiac Oct 1, 2011 02:22 PM
The gas cover lock follows the door locks - unlock doors, gas should be unlocked. If this is not the case, then remove the front, left side trunk liner and you will see the latch that holds the door from opening and you can manually move it.
XJRJeff Oct 1, 2011 02:23 PM
There is a lock on the fuel fill lid. It locks when the car is locked. It should unlock when when you unlock the car. If not then then the lock solenoid might have gone bad. I would not think it has any relation to your brake job, unless they had a reason to be messing around in the trunk. You can release the lock manually from inside the trunk. You will have to pull back the carpeting on the riverside of the trunk and that will expose the lock mechanism for the fuel fill lid. Then you just need to use your finger and you can push the lock mechanism into the unlock position. Hope this helps.
Arbus Oct 2, 2011 06:28 PM
It is fixed!
I took your advice and the opened the cap manually from the trunk. I left it ajar and drove to the gas station because I was very low on gas. When I got there, the attendant sprayed lithium lubricant on it and now it is working! Thank you for your help. It is much appreciated.
jdutchman Nov 21, 2011 06:08 PM
My gas cap cover became broken when opened. Any place other than Jag for replacement part? Thaks in advance.
(2004 xj)
Jhonathan Madrid Apr 1, 2013 07:07 PM
hey i have a question for you
Hey , i need to ask you , how can i open the gas tank ? , because for some reason the tank is not opening , i just bought the car its a 1992 jaguar . i cant figure if there is a button or something to open it can u please help me?
Timothy Anderson May 24, 2019 05:27 PM
I read the handbook and it said that doors must be unlocked I checked it out it works
in I checked the handbook and it said that doors must be unlocked I checked it out and it worked I hope it stays that easy
© 2026 MH Sub I, LLC dba Internet Brands
