going in for the TSB on "light pinging"
Old Apr 23, 2013 | 02:57 PM
mhamilton's Avatar
Default going in for the TSB on "light pinging"
Driving around the city Saturday with the windows open, heard my engine pinging like crazy on gentle accelerations and light throttle changes @ 30-35 mph. This was the first time I had the windows open driving around town.
Luckily some searching on the forum resulted in the TSB JTB00064 for my VIN range, and that's covered under my warranty. Dealer is going to do that update this week.
Hopefully that will fix it. I can't believe that the knock sensor won't dial the timing back when it occurs. Sounded like a popcorn maker under my hood.
Old Apr 23, 2013 | 03:00 PM
daxter1987's Avatar
Hey let us know what happened sounds like this could help a lot of people.
Old Apr 23, 2013 | 03:14 PM
Mikey's Avatar
What octane level of fuel are you using?
Old Apr 23, 2013 | 08:39 PM
mhamilton's Avatar
93, the highest I can get at the pumps. I'm sure the 10% ethanol does not help anything, but always try to use a top tier gasoline.
Old Apr 23, 2013 | 08:51 PM
Mikey's Avatar
That's very strange. Even if the knock sensor was dead as a door nail there should be no detonation on 91 or higher (?).
'93 octane' is '93 octane', irrespective of the fuel blend. Pure ethanol is actually 99 AKI octane so the E10 is not the culprit.
Old Apr 24, 2013 | 07:08 AM
mhamilton's Avatar
Perhaps... post #4 in here has the TSBs for the pinging on this VIN range: https://www.jaguarforums.com/forum/x...hrottle-46957/
It could be these engines have pistons or heads that accumulate carbon on sharp edges. The dealer was trying to sell me on "injector cleaning" but I know that wouldn't do anything. If the injectors were dirty I'd have long term fuel trims indicating the PCM trying to compensate.
Old Apr 24, 2013 | 11:03 PM
plums's Avatar
Or the maps in the ecm might not have allowed enough room for drift. In other words, the fueling or spark maps are a bit agressive. So the reflash would change to something with more margin for boundary conditions.
Old Apr 25, 2013 | 06:46 AM
mhamilton's Avatar
Was thinking about it last night on my drive home, I'll bet anything that had I turned on the a/c the pinging would have stopped.
Since I was crawling around town, mostly stopped at lights, windows open and climate control off, the radiator fan wouldn't run until the coolant got very hot. With a/c on the cooling fan runs on (at least) low speed, which would have broguht the engine temp back down and probably stopped all pinging.
If our temperature gauges weren't just dummy gauges, we could probably see this. In my last car, if I idled around town the gauge would creep up to the 3/4 mark before the fans kicked on, but turning on the a/c ran the fans and kept it dead center.
Last night I drove 30 miles on the interstate (a/c off), got off and drove about 2 miles through the city, no pinging at all. Only happened when I did extended city driving and let the engine heat soak.
Old Apr 26, 2013 | 06:38 AM
mhamilton's Avatar
On my way to the dealer yesterday afternoon I got off the interstate and the engine did do its light pinging as I drove through town, so at least it's reproducible. The dealer was nice enough to do the flash while I waited, so 45 minutes later my car was ready. Seems to be running very well now! No more ping, and it also seems to be accelerating smoother. It feels like the 1-2 shift is a lot better, so maybe the flash updated some other parameters as well. Either way, I'm happy
Dealer still says the 4.2L has issues with Ethanol, which I may or may not believe. He suggests if there's any more pinging I run Techron or its equivalent through a tank of gas. May do that either way, Techron seems to be good stuff.
Old Apr 26, 2013 | 09:06 AM
Mikey's Avatar
Thanks for the update.
Let us know if there's any changes.
Jpav27
Jul 31, 2022 06:43 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
redrover41
23
Sep 25, 2015 01:33 PM
avern1
Sep 8, 2015 06:25 PM
Mosers63
Sep 6, 2015 02:53 PM
