Headlight housings - and backwards compatibility
Old 04-19-2018, 01:22 PM
stham's Avatar
Default Headlight housings - and backwards compatibility
Someone hit my car the other day and smashed my headlight.
I'm trying to find a replacement.
All my internal components (ballast/bulb, leveling motor etc) are in good shape and work.
My question is,
Can I retrofit all my components including the leveling motor and ballast in a 06-09 headlight housing?
Old 04-19-2018, 02:45 PM
Partick the Cat's Avatar
You don't actually need a unit with a levelling motor; they were deleted quite early on because the self-levelling air suspension fulfils that function. Air suspension was originally only going to be fitted to 'high end' models but in the event all 350s had it. So, any HID unit, motor or no, should suit. Simpler than transplanting the innards I'd say.
Old 04-19-2018, 02:52 PM
stham's Avatar
I do understand it can be plugged in with no motor, but I do also know the leveling of the motors is directly operated by the air suspension, and I would honestly prefer to have 2 matching headlights in terms of leveling. My 05 XJR uses the leveling motors, I can see them adjust slightly as i drive sometimes
I just need to know if i can swap over the leveling motor and 12 pin ballast to the later 06+ model housing..
Old 04-20-2018, 11:22 AM
jackra_1's Avatar
Received 1,755 Likes on 1,326 Posts
Have you got an 06 housing in mind say on Ebay?
If so you could risk getting it an then return it at the cost of shipping?
If somewhere else can you return return it if it is not viable for your purpose?
Old 04-20-2018, 11:48 AM
stham's Avatar
I am speaking to a seller now, and I am trying to confirm with them it is the correct housing. In the event it isnt I wanted to see if it was possible to use it with my 05 spec.
People ask way too much for these headlights
Old 04-20-2018, 01:31 PM
jackra_1's Avatar
Good luck! Yes even used they seem to command a very high price!
That is why I will never mess with mine!
Rick7311
04-23-2016 08:51 AM
Sentinelist
03-17-2016 03:05 PM
krswen
07-02-2015 11:49 AM
Brutal
10-10-2012 12:55 PM
jemetz49
XJ40 ( XJ81 )
03-01-2009 12:09 PM
Quick Reply: Headlight housings - and backwards compatibility
