Help please! single sided S/C tensioner + S/C idler pulley part. no.?
Old Jul 8, 2015 | 09:15 AM
Matei Dima's Avatar
Default Help please! single sided S/C tensioner + S/C idler pulley part. no.?
Hi there,
Does anybody know where to get the single sided supercharger idler pulley, and tensioner? I have a terrible squeak which has accentuated in the last couple of months. When I changed my S/C belt, the mechanic pointed out the idler was on its way out, I can now confirm this is the case.
I went to rockauto, all they have is for the serpentine belt. Aren't there any compatible parts from the likes of Goodyear, or Dayco, or whatever? I do not want to convert to the double sided system Jag currently uses.
Please point me in the right direction.
Thanks!
Old Jul 8, 2015 | 10:00 AM
NBCat's Avatar
Supercharger belt tensioner assembly is C2C37057
Old Jul 8, 2015 | 10:43 AM
clifton94's Avatar
The idler has a bearing that can be replaced just go to a bearing supplier I did this cost me £5 just be careful when replacing it as the bearing does not go all the way in just measure the air gap between the pulley the bearing .The bearing number is hsr s 158 also the best belt is a gator belt put one on mine stopped the squeaky belt
Old Jul 10, 2015 | 10:02 AM
Matei Dima's Avatar
Thank you so much for your speedy responses! I do have a couple of things I don't understand...
NBCat, is that the code for the single sided belt tensioner? When I searched online, it said double sided. Or is it that it is of no consequence, since anyway the grooved side touches the pulley?
clifton94, I can't find a bearing with that code, the shop I went to told me thay have no record of it. Tried several places. Also tried google, nothing. I tried to school myself on the subject, but the standard denominations are quite different, e.g. 6010 instead of what you said. Could you please help me with that?
Old Jul 10, 2015 | 05:38 PM
clifton94's Avatar
This is the idler bearing
Old Jul 10, 2015 | 05:42 PM
clifton94's Avatar
Hope this helps my car is a 2006 model but it should be the same as yours
Old Jul 10, 2015 | 05:50 PM
NBCat's Avatar
Originally Posted by Matei Dima
...NBCat, is that the code for the single sided belt tensioner? When I searched online, it said double sided. Or is it that it is of no consequence, since anyway the grooved side touches the pulley?...
Here is the image from JEPC; tensioner is item number 4 in image; idler pulley is item 2.
Not sure what you mean by 'double sided'.
Attached Thumbnails Help please! single sided S/C tensioner + S/C idler pulley part. no.?-4.2_litre_sc_drive.png
Old Jul 10, 2015 | 05:58 PM
clifton94's Avatar
The new type belt supplied by jag has grooves on both sides but you have to fit the new kit before using the new type belt.The bearing I have photographed fits the idler number 2
Old Jul 10, 2015 | 06:03 PM
NBCat's Avatar
For the supercharger drive belt system on the 4.2 litre AJ-V8, the part numbers are:
C2C37057 - tensioner assembly
C2S46862 - idler pulley
C2C37055 - drive belt
Always provide the Jaguar dealership, or other parts house with the VIN to ensure the correct parts are sourced as there may be parts that have been superseded.
Old Jul 10, 2015 | 06:07 PM
NBCat's Avatar
If the belt has indeed been superseded, then yes, associated parts must be changed.
When a part is superseded, there is usually a reason such as cost, lack of supply or improved performance.
Old Jul 11, 2015 | 02:00 AM
clifton94's Avatar
They were superseded over in the UK as owners were having problems with them slipping when started from cold but if you fitted a gatorback belt made by good year it seemed to stop the slipping
Old Jul 11, 2015 | 02:09 AM
plums's Avatar
The single sided belt to double sided belt running change/tsb action
was first encountered in the X308/X100 with the 4.0L supercharged
engines. The double sided is completely inconvenient because the
belt is only available from Jaguar.
So, look here for the bearing numbers as they are likely the same:
https://www.jaguarforums.com/forum/x...acement-65171/
Be warned that the bolt on one of the bearings is left hand thread.
I forget which. If you try to undo it in the usual direction and try
hard enough, you will snap the bolt.
All four bearings can be had for $20 as they are popular sizes used
in a lot of applications. As a matter of fact, they can be bought at
NAPA.
Old Jul 14, 2015 | 04:47 AM
Matei Dima's Avatar
I did my research, went to all the shops, looked online for the bearing, nothing.
Clifton94, could you please post a link as to where I could buy the bearing? All the shops said they never heard of that bearing, and that it might be some special variety. I suspect the only place would be America, and that I'd pay $100 in shipping and taxes for a $2 bearing... I sooo hope the tax union between EU & US is instated sometime soon!...
My car squeaks like hell, and it's certain I can't install Andre's TS kit when it arrives in August. I have the Gates belt, so belt is ruled out as the problem.
Hope I'll get through with it.
Old Jul 14, 2015 | 05:13 AM
Matei Dima's Avatar
NBCat, thanks, I think I am clear now.
Also Plums, I will look into that, I'll order those codes and see if they fit.
Thank you all
Old Jul 14, 2015 | 12:30 PM
clifton94's Avatar
Did you find the bearings
Old Jul 14, 2015 | 11:31 PM
plums's Avatar
in the UK,
bearingking.co.uk
Old Jul 16, 2015 | 06:12 PM
Matei Dima's Avatar
Yup,
found them, ordered them from the site.
Thanks a bunch guys! I just hope they're the same as with the X308s.
Will report back.
Razor
Aug 28, 2019 08:34 PM
SCMike
Sep 22, 2015 07:34 PM
Bowman
Sep 15, 2015 06:54 AM
Jay48
Sep 7, 2015 09:30 PM
Tar
Sep 6, 2015 11:24 AM
