The hose covering the air-suspension wire
Old Jan 16, 2024 | 01:36 PM
Jaroslav Záruba's Avatar
Default The hose covering the air-suspension wire
Hi
Is it possible to replace these? I am unable to find the product number.
If the original is either unobtainable or absurdly expensive I am even okay with something sort-of-sleek an electrician would use.
I can't look at this.
one is pretty much gone
the other one is waving good-bye
Old Jan 16, 2024 | 03:39 PM
Thomas-S.'s Avatar
If I look at your second picture and compare it with my car, I would say that it is not waving good-bye, but that it looks exactly like it left the factory...
At the bottom of the picture you can see how the older version of the pre-facelift versions looks like:
The picture was taken when I did some cleaning works on the engine.
Best regards,
Thomas
Old Jan 16, 2024 | 03:54 PM
It appears that the hose #1 has its end still latching to the strut, while the more complete hose #2 is exposing the wires near the connector.
But maybe you're right, I'll lean into the engine bay tomorrow to take a better look.
Old Jan 16, 2024 | 10:25 PM
Pete M's Avatar
Hi,
My car looked the same. I bought a length of spiral plastic tubing, usually called Spirap. The 4mm size is good for this, but there are larger sizes available.
4mm Spirap tubing
Pete M
Bob Hornby
Jul 3, 2023 08:00 AM
kpholsith
Jun 23, 2022 04:41 PM
stevepaa
May 30, 2022 07:34 PM
wsn03
Jan 30, 2022 02:56 AM
zidjan
Dec 21, 2019 10:38 PM
