How do parking aid sensors come out?
Can someone describe how this is done? Do the sensors twist? Are there tabs to lift or press? Does the whole thing come out, or just the inner part? I see replacements for sale, but just looking at them, I don't get much of a clue as to how they are held or mounted. Any help appreciated.
Just the center part comes out.
There are two long opposing tabs that come up the sides of the sensor with "clip edges" that clip over the inward facing end of the sensor.
I found that you have to lever both these tabs quite a bit away from the sensor before they come out.
I pressed on the outer bumper side while levering those tabs and the sensor pops out.
The tabs I am talking about go up the whole length of that sensor and are what the sensor fits into.
Originally Posted by Boomer from Boston
Mag -
Someone in one of these threads had said that you could get access to the outer sensors via the opening left when you remove the tail light. Judging from your last picture, I don't see how that would be possible.
Bumper seemed easier to remove for me but feel free to do as you like.
If you can purchase a 'complete' sensor (with the attachment 'tang'), you may be able to 'rehearse' the release motion and get it down.
I couldn't figure it out, so that's what I had to do.
Once I had the complete assembly in hand, it was no big deal to twist/release the sensor.
Apologies, its been so long, I don't recall the movements at this time...
Mag
Tail light removal is optional, bumper removal on one side is not.
I did my right rear corner sensor through the tail light opening without removing the bumper cover. you can't see it but you can feel it. Do not twist the sensor. It comes straight out once you pry up the tabs on the holder that is glued to the inside of the bumper cover. I think the tabs were on the top and bottom of the holder, but not totally certain.
