I found a supplier for the TPS 198500-3300
Old Oct 10, 2012 | 07:23 AM
Tony Swash's Avatar
Default I found a supplier for the TPS 198500-3300
I finally found a supplier who can make me the dreaded TPS 198500-3300 made by Denso.
This brat causes the P2135 fault and limp mode.
These devices will fail, its just when and it saves the cost of a new TB as Jaguar will not supply it on its own. If the demand is high enough I will get some made.
Old Oct 10, 2012 | 07:36 PM
Jag400's Avatar
Im game please let me know. Thanks in advance.
Old Oct 11, 2012 | 05:25 AM
Tony Swash's Avatar
We need a minimum order of 50 pieces. I have posted on the UK website as well
Old Oct 11, 2012 | 06:17 AM
Sean B's Avatar
and the cost is?
Old Oct 11, 2012 | 07:15 AM
Clamdigger's Avatar
Which model and year engines does this TPS fit, I could be interested
Old Oct 12, 2012 | 12:02 PM
Cambo's Avatar
2002 onwards S-Type 2.5, 3.0, 4.2 & S/C
X350 XJ 3.0, 3.5, 4.2 & S/C
X-Type 2.5 & 3.0.
Might fit the 4.2 XK's but we are not sure yet.
Might fit the AJ27 V8 in the later X308 & X100, but again needs to be tested.
Old Oct 12, 2012 | 04:01 PM
meirion1's Avatar
Default Tps
I see that the manufacturer is ISO 9001 certified.
Put me down for one please Tony
Old Oct 12, 2012 | 11:53 PM
evilfij's Avatar
Count me in if the price is within reason. Honestly, if it is reasonable, I would buy a bunch to resell to get us to 50.
Old Dec 23, 2012 | 07:04 PM
EZDriver's Avatar
I need one for my 1995 X300. Can your friend provide one for that car?
Old Dec 24, 2012 | 11:23 AM
Jag XJ8 Red's Avatar
Banned
Where does this stand? I am in for two.
Old Dec 25, 2012 | 11:19 AM
cjd's Avatar
cjd
I can use one for my TB I had to replace...
John
Old Dec 25, 2012 | 11:37 AM
SuperTrav's Avatar
I'm IN.
Old Dec 25, 2012 | 05:53 PM
XJL's Avatar
XJL
How much?
Old Dec 27, 2012 | 07:01 PM
RobHathaway's Avatar
Count me in for two units. Logistics?
Old Dec 29, 2012 | 01:12 AM
randyshear's Avatar
Price?
Old Dec 29, 2012 | 07:31 AM
Robert Page's Avatar
Interesting! Could be in for my spares shelf.
Old Dec 29, 2012 | 12:33 PM
usmc1211's Avatar
Count me in on One. Is there a price? and will it come with an installation procedure? I figure that the sensor may need to be aligned.?
Old Dec 29, 2012 | 04:33 PM
meirion1's Avatar
"I figure that the sensor may need to be aligned.?''
Yes you are correct, I have a note of this somewhere,butterfly is 15 deg open at idle.
I also have an used TB and can see that the TPS has two oval slots for the attachment screws and both screws are not in the same position and sealed with a dab of paint.
ie the TPS has been set to a voltage.
Old Dec 29, 2012 | 07:47 PM
lcmjaguar's Avatar
Regarding the Throttle Position Sensor Part Number TPS 198500-3300 made by Denso.
If the supplier is Guangzhou Sensar Automobile Electronic Co., Ltd.
from Guangdong, China (Mainland), I see they are ISO certified and are a maker of Auto Sensor, Crankshaft Sensor, Camshaft Sensor, Speed Sensor, Throttle Position Sensor. I see they quote a FOB price that is real cheep per 20/pc. with minmum 50 piece order. This will be very promising if this is your supplier. You will have to let us know a price you will be charging...everyone is asking in order to commit.
LCMJAGUAR
XJ8
Old Dec 29, 2012 | 10:10 PM
Banned
I think the OP has abandoned his thread.
