Key Fob Programming
I only have one key for my 05 XJR. I have read the forum and it explains that Jaguar IDS is required for programming an additional remote if you have one key/remote fob. Is the WDS system not capable of programming a key/remote fob?
Programming a key requires SDD. I think the old WDS system would have to have MANY updates to be capable of doing a 2005 security programming alteration...3 but I'm not sure. I'm driving up your way in 3 weeks with my laptop w/ SDD and cable...shall I swing through Versailles?
Originally Posted by Woodford Jag
(Post 1020209)
Hi Woodford, I bought some extra new key fob remotes for our '04 XJR before I had JLR SDD, and this procedure worked great to program all four of our remotes (even though the Jaguar manual stated that up to three remotes can be programmed): 1. Open driver's door. 2. Hold the highbeam selector arm toward you. 3. Insert ignition key and turn to first position (Accessory). 4. Release highbeam selector arm and then pull and release arm 4 times. After the 4th time you will hear a chime indicating that the system is in programming mode. 5. Press the lock button on each remote to program it in. I think there is a maximum time allotment for this, but I didn't make a note of it. You don't have to hurry. 6. Step out of the car, close the driver's door and test each remote. If a remote does not work, it may need a new CR2032 battery. I hope this also works on your '05. Cheers, Don |
Originally Posted by Don B
(Post 1022879)
Hi Woodford Jag,
Key Fob Programming
Thank you,
I need to order a Key Fob and Key blank then have it cut. H20Boy, Your offer would be great if your gonna be in the area. It would be nice to meet another forum member and I hope you would be driving your Jaguar, I would like to check the Audio System you installed. Woodford |
From what I have seen here its supposed to be five stalk flashes not four...Mine seems to only do it properly with four flashes...
Program key, not fob
(Post 1020209)
The key contains the immobilizer. This is what requires SDD if you only have one. I have a working key. The other key purchased for 100.00 turns, shows the flashing red light. Will not start vehicle. Need to find a person with SDD close to Houston. Thought about ordering a key from dealer but they will not return my calls. |
I bought new keyfobs because I lost one of my keys (again).
If I program the keyfobs, then find that key, will it not work anymore? |
Yes, but you will have to reprogram, all them again, at the same time
hi don b
i did my keys a few weeks ago, old programmed key and a new complete key precut i used same to programme buttons.. but needs a diagnostic for the chip in key part of fob !... i used thinkcar 2 costs $10 to download the key programming for your vin# worked fine for my 2005 x350 also u get 2 or 3 vin numbers to load up the programme for each make of vehicle, this lasts 1 year then you pay for another year, if required, however the obd part stays free, works for me as plug in unit cost £34 delivered on ebay lots of sellers on there for this item. i also purchased the air suspension $5 to look at that as i had the usual suspension fault on the dash, ime going to rebuid the compressor and change desicant etc in summer... payments made thro paypal |
(Post 1022879)
Hi Woodford,
