Loud banging/ knocking noise from engine area when car starts on cold mornings.
When i start the car first thing on a cold morning it has a definate loud banging /knocking noise coming from the front of the engine compartment.
It probably lasts 10 -15 secs and disappears. It is loud enough to hear inside the cabin too. It happens randomly in the cold, but ONLY when its cold.
Any ideas?
Also the 30f temps have bought the low vehicle and air suspension failures codes back which don't concern me currently as I am unable to drive.
Any ideas?
Loud banging noises are not cool. Keep us posted.
Is it coming from the front right (passenger) bumper area? If so, that is the Air Injector pump or some valve for it. More of a loud tick/thump than a bang. My car did the exact same thing last winter whenever the temp was below 40F. The pump only runs for the first 20-30 seconds on cold starts.
When my XJ8L plastic thermostat housing broke, this was the sound I heard. At the start, kind of cold weather. It then would overheat when stopped, but showed no sign of failure when driving. So, the cheap plastic housing broke, partially blocking/leaking the inside passages (which you cannot see from the engine bay, i.e. there was no coolant leak).
It dropped below 30f last night and the Jag has dropped and I have the low vehicle and suspension fault warning lights on. Dang, I thought changing the compressor piston ring set may have resolved the issue (and tightened the brass connector on the compressor air line). Ah well.
I definately heard the front left air strut throwing a hissy fit and sank pretty much immediately on start up. That looks like the culprit.
I will be checking the connector with bubbly water and see if it is that, if not then just wait until the weather warms up a bit before driving it (and the snow and ice has dissipated). which will probably be tomorrow (knowing Texas weather!).
I also had the knocking again on startup in these cold temps. I will diagnose this now as the cold conditions will allow me to have the knock more often.
BrentGardner
26
04-17-2024 05:19 PM
1964Daimler
09-02-2015 11:41 PM
FS[MidWest]: FS: 1999 VDP *lots of pics* in mid-Missouri
souldoubt
08-25-2015 08:15 PM
