no phone connect dialog?
Old Sep 9, 2021 | 01:45 AM
psyo's Avatar
Default no phone connect dialog?
I recently bought an x358 and I'm trying to pair the phone.
as per manual i should press the phone button and get a pairing option.
but al it says is: no phone connected and then reverts back to whatever screen was open before pressing the button.
in the boot there is a module: 7w93-10d893-ab which should actually be the most up to date bluetooth module model you can get for these types of cars.
Is there some undocumented way of pairing the phone or is the module broken?
what can this be, how can i troubleshoot it?
Old Sep 12, 2021 | 05:18 AM
psyo's Avatar
no one?
reading up some more about this and i see a lot of mentions about something called a BTUM and that it should be under the armrest.
i didnt notice to be anything there.
also not clear to me if you need it if you have the 'silver' bt module... i seem to have the plastic one (as shown in picture)
Old Sep 12, 2021 | 09:41 AM
jackra_1's Avatar
You probably have the better plastic module that supports several phones and does not need a BTUM. The older style silver metal ones did not in the research that I did.
If all your other modules connected to the fiber optic ring are working then there is not a problem with the ring/loop.
Run a simple diagnostic to see if all modules are listed. This can be done from the dash and appropriate buttons being pressed. I forget how now but others might chime in.
Even if it is recognised it still could be broken. A microphone and an aerial/antenna are required just not the BTUM.
Old Sep 13, 2021 | 03:28 PM
psyo's Avatar
looks bad i think, it says:
phone type: none
could this be a bad module or are did all XJ's come with a BT module installed but not necessarily enabled through software or something?
is there a way to enable it?
the car has voice command and mics installed so looks like everything is there to make it work.
Old Sep 13, 2021 | 04:36 PM
jackra_1's Avatar
Should be plug and play if it is working.
Old Oct 31, 2021 | 05:53 AM
psyo's Avatar
i bought a secondhand replacement for the module, so then i know if the current one is broken.
should i disconnect the battery before replacing it?
i know on my previous range rover evoque disconnecting the battery had implications for the board computer and the dealer had to restore some settings or something. I probably will be fine with this jag since it's much older tech, right?
Old Oct 31, 2021 | 02:25 PM
jackra_1's Avatar
Does your voice command work?
If it does then the Bluetooth module is suspect.
Did you connect an antenna for the BT module?
Old Nov 1, 2021 | 03:31 PM
psyo's Avatar
alas, replaced module, but still no phone.
ill have the dealer figure it out...
Old Nov 1, 2021 | 04:06 PM
jackra_1's Avatar
I am sure you have however I will ask whether you have propely connected the electrical connecter?
Old Nov 1, 2021 | 09:45 PM
veffremov's Avatar
Friend, is your head unit original? It says X409, which is X-type, not XJ VDP. By the looks of it nothing is connected to the fiber optic system, so it is either dead or not activated at all.
Graham Sears
Dec 6, 2019 09:02 AM
xtypemalta
Feb 21, 2014 06:16 PM
WinterJag
Aug 4, 2013 06:03 AM
iceotron
Mar 19, 2010 01:58 PM
ukjagowner
Audio/Visual Electronics
Feb 13, 2008 01:32 PM
