P0300, P0301, P0302, P0304 dies after replacing hoses and thermostat
Old Jul 19, 2017 | 02:02 PM
StellaLunaGardens's Avatar
Default P0300, P0301, P0302, P0304 dies after replacing hoses and thermostat
i just replaced all the hoses, thermostat and housing in my '08 XJ8. I took it for a twenty minute test drive, no problems, the next day, I went for another test drive, after about a mile, she started sputtering and the check engine and restricted performance light came on. The codes I got are P0300, 301, 302 & 304.
Is this a weird coincidence, and another problem just started, or should I look at my work and see if I missed something?
Old Jul 19, 2017 | 02:16 PM
JagV8's Avatar
Most are 2-trip codes which is why it was your 2nd drive when they flagged.
It does tend to be the most recent work that's worth suspecting.
Old Jul 19, 2017 | 03:01 PM
Default New hoses and thermostat is all I've done
I haven't done any other work except the hoses and thermostat.
Old Jul 20, 2017 | 10:02 AM
Qvhk's Avatar
Found some write-up about these codes in JagRepair.com:
http://www.jagrepair.com/images/Auto...to%20P0308.pdf
So these codes means multiple cylinder misfiring, and misfiring specific to Cylinders #1, #2 and #4; enough clues for a more detailed investigation.
Old Jul 20, 2017 | 12:29 PM
XJ8JR's Avatar
Did you spill any coolant on the wiring or ignition coils?
Old Jul 20, 2017 | 01:44 PM
Default Possibly
When the hose busted, it sprayed coolant everywhere, under the hood. That was the second hose to break on me in a year, so I decided to replace them all
Old Jul 20, 2017 | 01:55 PM
XJ8JR's Avatar
I would spray and clean out all the wiring and connectors with electronics cleaner first. Cheap and easy might do the trick.
Old Jul 20, 2017 | 02:05 PM
Thank you!
