XJ8L maintenance
XJ8L maintenance
I just picked up an '05 XJ8L with 63k miles. I looked at the thread above to find some of the maintenance items I should take care of and I'll be having the trans fluid and filter done along with the reflashing if what I'm feeling is the lurching mentioned. It's minor, but feels a little bit lurchy at times.
I also noticed that around curves at decent speed, bumps upset the steering a bit more than I feel comfortable with. I'm thinking about the Arnott coil over kit and just take care of the suspension preemptively and while I'm in there, I'm curious what other bits I should be swapping or at least taking a close look at. I could picture it being a good time to swap tie rod ends, ball joints and bushings. Thoughts?
Received 9,005 Likes
There's a thread running in the X358 section, gives so much info
I'm pretty sure that the bushings are available from SNG Barratt ( from sponsor that gives member discounts too )
There are other sources too I'm sure and others will chime in
Not sure if you're doing some / all of the work yourself?
Or perhaps getting someone to do it for you......As you say, either way you're in that area anyway and have done 90% of the teardown so why not, especially f she's going to be a keeper for several years.
Good luck
Good luck
My brother has a hoist and a host of tools most people could only dream of. I'd probably try to DIY with some assistance from him.
ebay is where I started my search, but lately, I've been a little more concerned about the parts suppliers on there.
Thanks again, I'll do some digging around about sources, that won't be an issue, but thanks for the nudges in the right direction.
dmatthewman
09-30-2015 10:10 AM
