REAR Brake pads NO Fit
Bought pads from Amazon said they fit
I compressed all 4 pistons on my calibers and only on pad will fit in on either side. So I removed the entire caliber and put bith pads in and tried to slide caliber back over disk and the opening between pads I can eyeball and see its too narrow. Could the pads be too thick? |
2 Attachment(s)
Note that the brakes changed at VIN G45704.
What are the pads you bought, and how much off fitting are they? With the OEM pads on my pre-G45704 XJ6 it is a tight fit if the discs are new but they will fit with perseverance. You may find the attached useful. |
On my 06 SV8 I had similar issue. I discovered that the caliper rewind tool needed an xtra 1/4 turn to make the clearance for the tight fit.
For what it is worth, I have an early VIN H00099 with Akenobno Euro pads 1095 on the rear. |
It would help to know year model and possibly vin to identify the correct pad.
| All times are GMT -5. The time now is 05:54 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
