Rear off side lock solenoid not working
Old Jun 17, 2013 | 09:37 AM
Gino's Avatar
Default Rear off side lock solenoid not working
Hello All,
I never realised I had a problem with my rear offside door not locking until somebody tried to get into the car last night!!
Anyhow, it's not working, all the other locks work fine.
Fortunately the alarm still operated as it should.
Is there something I should try first to isolate the problem or are there any fuses I can check?
Thanks in advance,
Gino.
Old Jun 17, 2013 | 09:40 AM
oldmots's Avatar
When one of mine quit working, I had to replace it.
Old Jun 17, 2013 | 02:00 PM
Fraser Mitchell's Avatar
There is normally a tiny little switch inside that fails, but is not separately available, so the whole shebang has to be replaced. They are not hugely expensive, but much more than a stupid little switch !
Old Jun 17, 2013 | 02:13 PM
Gino's Avatar
Thanks guys. I took out the old solenoid tonight and tested it on the bench, it is definitely 'dead'. Ah well, looks like Ill have to find a replacement. In the mean time i disconnected the operating rod from the handle to the switch and put everything back together, the door can be opened from inside the car but the handle does nothing!!
G.
Old Jun 17, 2013 | 02:20 PM
Gino's Avatar
Sorry, should have asked, does anyone have the correct part number please?
the car is 2009 2.7 tdvi executive & its rear o/s (uk), thanks,
G
Old Jun 17, 2013 | 06:11 PM
meirion1's Avatar
You are in luck-you are in Manchester!
The failed component will be the microswitch in the lock and you will have
noticed that it says FORD on the lock!
I have replaced the microswitch but you will find it easier to replace the lock.
I know for a fact that an 05 Mondeo has the same lock. Mine cost 10 GBP used!
Locks from smaller Fords are a bit different.
Let us know how you get on.
Old Jun 21, 2013 | 06:15 AM
Gino's Avatar
Hi All,
I ended up ordering a new genuine Jaguar assembly which I think I got for a good price (about half of list price), part number C2C30697. All being well I will fit it this weekend.
My plan is to strip the old one down and see if I can repair it, if things go to plan I'll take pictures and post.
Thanks for all your help guys,
G
BrentGardner
29
Dec 16, 2024 12:13 AM
johnnie ryall
Oct 19, 2015 09:44 PM
msdg137
Sep 16, 2015 06:24 AM
Steve Langridge
Sep 3, 2015 07:35 PM
johanasu
Sep 3, 2015 12:39 PM
