Rear park sensors
Rear park sensors
My rear sensors had become randomly unusable because of a continuous beeeeep so I removed the
rear bumper and placed the sensors and wiring on the crash bar then:
Ign on
Reverse selected
Park brake on
Forunately the system was faulty at the time so I started to subtitute each sensor with a 'new' one and on the second one the beeping stopped and all sensors were working.
It sounds easy but it took about 4 hours altogether to repair and put all the bits back.
BTW Anyone had any experience with the $6 Chinese sensors?
Ign on
Reverse selected
Park brake on
I had a fault in the front sensors, it is possible to find the faulty sensor by getting your ear almost touching each sensor in turn, if they are working, there will be a very light "clicking", the faulty sensor will be silent. I found my front left centre sensor to be silent, changed it out and all working fine. Took me about 5 minutes to change it out.
It really is a very light clicking, barely audible, I had to get on my knees and almost had my ear touching the centre of the sensor to hear it, It's one of those sound that until you actually hear it, you are not sure if you are hearing it. If the engine is running, it might even be enough to drown out the sound at the rear. I switched on the ignition, but didn't start the engine, put the car in reverse and that's when I could hear it.
JimC64
01-30-2015 11:31 AM
