Warranty on Air Suspension
Old Dec 26, 2008 | 05:47 PM
Brutal's Avatar
Default RE: Warranty on Air Suspension
no select doesnt cover the air springs, but they do cover the pump, and if the pump over pressurized the system and blew out the springs they would be covered. But that is a HUGE streach. But it very doubtfull both front springs went out at the same time, more like they dont know which one, but if they properly ran the diagnostic flowchart theyde know which 1. If you disconnect the air valve blocks electrical connector in the trunk under the spare, the system wont add air. This will let 1 corner drop overnight more than the other, this will tell you which ones leaking.
Wolfy
May 28, 2024 08:06 AM
Mugatu
22
Jun 23, 2020 01:50 PM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
SeanU
Sep 11, 2015 12:56 PM
philwarner
Sep 3, 2015 10:14 PM
