Washer Fluid
Old Feb 16, 2013 | 10:28 AM
Sidvicious's Avatar
Exclamation Washer Fluid
Have a quick question, I recently put Rain X washer fluid into my XJ8 but now I'm getting a low washer fluid message. I noticed fluid leaking on the front left under the headlights but thought nothing of it. I assume there must be a problem, all help is greatly appreciated. I had no code before adding the fluid but now I do have one since I added it, makes no sense. Thanks
Old Feb 16, 2013 | 04:17 PM
Fraser Mitchell's Avatar
Like how recently ? The screen and headlight washers combined use up a hell of a lot of fluid in winter with headlights being on more. Headlight washer is very generous with fluid in my experience.
Of course it might just be coincidence, and you have a crack in the reservoir. Inspection is a PITA as you have to take off the wheel arch liner.
Old Feb 17, 2013 | 11:58 AM
Sidvicious's Avatar
I put it in yesterday and within minutes got the message low washer fluid, never had the message before until now. I put probably half a bottle in there. The chamber I put it in has a blue flip door, hope I put it in the right one pretty sure I did lol.
Old Feb 18, 2013 | 10:55 AM
Sidvicious's Avatar
Ok so I've found the leak but need to know how to get to it. Seems to be pissing out right behind the drivers front tire. All help is appreciated to get this fixed as its not detrimental but I like everything to be in working order. Going to change the oil as well today. Thanks!
Old Feb 18, 2013 | 12:59 PM
It could be just a pipe has come off, as reservoir leaks are very uncommon.
Old Feb 18, 2013 | 01:49 PM
Sidvicious's Avatar
What's the best way to check and see if a pipe came loose? Also how much oil do I put in? On here it says 6 liters but at my local shop it's calling for 6.9 liters. Thanks!
Old Feb 18, 2013 | 02:24 PM
H20boy's Avatar
Remove that under tray yourself, that'll expose a lot. If you need more, you may have to pull the bumper...the hoses are clipped to the bumper. My guess is pressure blew one apart at a fitting. Those headlamp washers plug easily.
Old Feb 18, 2013 | 03:05 PM
Sidvicious's Avatar
Thank you very much, going to pull the car onto the ramps in a few. How much oil do I put in? I'm changing the oil filter as well. Thanks!
RaceDiagnostics
Apr 4, 2016 04:00 PM
millertic
Sep 30, 2015 08:11 PM
dmatthewman
Sep 30, 2015 10:10 AM
jjmiah217
Sep 28, 2015 09:09 AM
