What did you do to your X350/X358 today?
Old Apr 23, 2018 | 03:22 PM
  #501
Wingrider's Avatar
Smile
abonano wrote; Rested it on a single step ladder while handling the sensor swap.
Use whatever's handy, to get the job handled.
__________________
Old Apr 24, 2018 | 06:47 PM
  #502
abonano's Avatar
Correct wingrider. Tackled my 4 dead alpine door speakers with the "speaker fix"... yep, all 4 were silent...
Wow, what a difference!
Taking off the door panels was pretty easy...
Old Apr 25, 2018 | 09:08 AM
  #503
nsubbu8854's Avatar
Post
I have installed the hood struts on my 08 XJR. Ordered the 3 PC Pedal set and got it installed by my mechanic. Replaced the front lower control arms on both the sides. Still have few pending items 1) Right side passenger mirror comes loose (need to replace/repair) 2) I am getting a huge noise (front right side) when I start the car early in the morning, it only happens when I drive it at low speeds - it feels as if something is holding the brakes pretty tight and makes huge noise.
Old Apr 25, 2018 | 02:12 PM
  #504
Wingrider's Avatar
Smile
Finally got things moving along with replacing the thermostat, with the junk plastic housing P O S. Did the water pump, (auxiliary pump looked new, no heat when i looked at the car, at the dealer), serpentine belt, tensioner, idler pulley, fuel filter, with new coolant, while there.Hope to be finished working on it for a while, and get a chance to drive it, less than a thousand miles on it, since last fall.
Old Apr 27, 2018 | 09:01 PM
  #505
meirion1's Avatar
My auto wipers seemed sluggish after having the windscreen replaced.
I had a look at the sensor with a torch and there appeared to be some condensation
in there.
I removed the rear view mirror and the sensor and a gel like window (soft plastic) just
fell out.
It seemed quite opaque so cleaned it with a little turps along with the window in the
screen.
Replaced the whole lot and it's certainly responding but will have to wait for fine rain
for a real test
Old Apr 28, 2018 | 12:57 AM
  #506
paddyx350's Avatar
My steering wheel leather has been pretty badly scratched and damaged since I got the car, presumably from a PO who wore a ring on their left hand and drove with the same.
Got a leather repair kit from the furniture clinic in the UK with jaguar specific 'warm charcoal' colour/dye.
Filled pitting with the flexible filler provided, dried off with a hair dryer. Put on new colour, dried off. Put on a semi-gloss top coat, looks great.
Have also used the same kit to repair scratches on the seats with pretty good results for a hamfisted fool like me.
Old Apr 30, 2018 | 02:49 PM
  #507
lc3566's Avatar
Replaced NS front level sensor - it was throwing out bad values & causing some crazy symptoms. (rear suspension dropped right down & wouldn't raise, all 4 corners different crazy heights) After 3 recalibrations & resets, fingers crossed it seems to be ok! Also had OS lower shock bush replaced & a new battery. £700 poorer for all the above & I've got a noisy & weak compressor to deal with next! Yes, I'd be wealthier man had I bought a vauxhall corsa - but my heart would be empty........(sigh)
Old Apr 30, 2018 | 05:29 PM
  #508
meirion1's Avatar
"Replaced NS front level sensor"
Very unusual for the sensor to fail sometimes they are damaged
or have a wiring problem or not replaced after work on the car.
Old May 1, 2018 | 01:10 AM
  #509
-Greg-'s Avatar
Just yesterday I had to park the car for another air strut refurb. This time it was front left one and I even got a discount. anyway, everything works great now and I think it leaked for a very long time. My front was bouncy over bumps and when stopping rapidly. Now it is much more firm and composed. I was said the shock inside the Air Strut was also refurbished because it had a small leak.
Next step - I need to find new rotors, refurbish calipers and put back everything with new pads...
Old May 1, 2018 | 05:53 AM
  #510
lc3566's Avatar
Well, car is back with the specialist today - although perfectly level it's riding way too low after the work. No fault warning on the dash, the garage is going to try another recalibration/reset. I've read quite a few posts where people have had faults after work has been done. Hoping this next reset cures it, if not I'm guessing leaks, relay or even suspension control module issues.
The X350 is probably the nicest car I've owned but I wish Jaguar had gone with conventional suspension when designing it!
Old May 1, 2018 | 09:56 AM
  #511
lc3566's Avatar
problem seems sorted (I hope!) apparently the car had set itself to "towing mode" & had dropped very low, refusing to raise above a certain level. Specialist reset again at no extra cost. (Stephen Heywood Jaguar, 10 miles outside central Manchester, highly recommended) Now I'm just hoping the old Jag holds together for my 1500 mile road trip tomorrow!
Old May 1, 2018 | 02:25 PM
  #512
Fraser Mitchell's Avatar
On Sunday coming back home after a run into Wales, heard a couple of squeaks that sounded like brake squeal, except I wasn't braking ! Anyway today, when I went for my chiropractor session, heard them again. On arrival at the chiros, the LH front wheel was much hotter than the RH front and also had a load of black brake dust on the wheel. I also noticed judder on braking too.
So I took the car to my local mechanic who confirmed my prognosis. Only problem is he can't deal with the matter until next week. He's going to check for drag, and loose off the caliper if necessary. If that doesn't work, I'm going to swap-out the caliper.
Old May 1, 2018 | 03:37 PM
  #513
Etypephil's Avatar
Put more miles on the clock, gave it a waterless wash.
Old May 2, 2018 | 09:46 AM
  #514
Dan R's Avatar
What is a waterless wash and secondly do the green grids inn the lawn enable you to drive on it?
Old May 2, 2018 | 01:01 PM
  #515
Etypephil's Avatar
Waterless wash and wax is a chemical cleaner such as:
https://www.google.co.uk/search?q=tr...48199804769173
Triplewax Shake & Shine Shampoo
It is good for quickly cleaning superficially dirty cars, but not for caked on grime and mud etc. The key is to keep turning the cloth and change it when dirty. There are many brands, although Triplex is the one I have found the most effective, and easy to use.
The grids in the photo is a heavy duty turf reinforcing mesh which can be driven over or parked on without ruining your lawn. The grass grows through and eventually it becomes almost invisible.
https://www.matsgrids.co.uk/grass-re..._size-2m_x_10m
I used far more U pins than the instructions suggested to fix it down as my soil is clay. It's been down just three weeks, which is why you can see a few bare patches where I repaired previous damage to the lawn, and the grass has yet to re-establish itself. I needed additional parking, but didn't want to lose the grass; we have had heavy rain since with no signs of any movement or sinking.
Sorry the links are for British sites but I'm sure that similar products are available on your side of the Atlantic. :-)
Old May 2, 2018 | 06:42 PM
  #516
Wingrider's Avatar
Smile
Sent in the old stock shocks, from my 04 XJ8 that i replaced with Arnotts little over a year ago, to R M T. For the cost, the lifetime warranty, as well as keeping all the features of the C A T S system, no real choice in the matter. The Arnotts work well, & did not know about rebuilding the old ones at the time. The ones on the 07, still hold air, but they feel pretty well worn, with an irritating squeak. at 98,000+ miles, rebuilds sound like my best option.
Old May 6, 2018 | 12:46 PM
  #517
knight2rider's Avatar
Washed the Cat
Old May 6, 2018 | 10:26 PM
  #518
Etypephil's Avatar
To prevent further random alarm soundings waking me, and the rest of the neighbourhood, bypassed the bonnet open sensor by bridging its connector plug terminals with copper wire.
Old May 7, 2018 | 02:55 AM
  #519
Aix's Avatar
Aix
Sentenced her to prison for continuous misbehavior ...
Recently a major scratching sound started during braking. So when I checked arund I found the right read brake disc was scraped away by the brake pad, or by the looks probably by the sorry remains of the pad carrier.
These continuous issues are causing a certain disenchantment between me and my green toy ...
So besides ordering new discs and pads I parked her in isolation
and then locked her up
I'm already looking forward to changing the discs and potentially brake piston or even one caliper under the spacious conditions besides the car ...
With around 40cm room to either side I can only hope the disc comes off without too much of a fight
Maybe the old saying about needing two Jaguars is still valid to a certain amount ...
And never mind my signature, no amount of cost advantage from driving LPG can even remotely compensate for the spare part requirements this car seems to develop all of a sudden
Old May 7, 2018 | 05:45 PM
  #520
meirion1's Avatar
Park it 1 cm to one side and then you will have 79 cm in which to work!
Be careful when you jack it up-you might use up that 1cm.
My front discs came off no problem when I did mine but they don't salt the roads here
thank god.
