What did you do to your X350/X358 today?
Old May 11, 2020 | 05:07 PM
  #961
Wingrider's Avatar
Finally got the rear uppers & lowers replaced on the 04, did the 07's in January.
They were in worse shape than the 04's were.
They both needed them replaced, both with over a hundred thousand miles
Can't get it aligned till Thursday when i called this morning.
Glad i have two, one to drive while fixing the other.
Starting to look like i might finally be getting caught up.
For anyone curious about the lower rears.
The 04 Lincoln LS arms, fit the 04, but the hub bushing opening is smaller on the 07.
Had to get Lemforder's to fit the 07's hubs properly without modifying them.
Old May 13, 2020 | 09:32 AM
  #962
colince's Avatar
Default Wish I could go for a drive
Covered the car in its outside cover after the wind had done its worst.
Waiting for the virus threat to reduce then we can go out, have to take our own refreshments as all pubs, clubs and cafes are going to be shut for another month or so at least...........
Old May 13, 2020 | 12:50 PM
  #963
JagsteRJX's Avatar
Had a Viezu tune installed, limiter removed too. Car pulls harder and has quicker response, S/C whine louder too.
Old May 13, 2020 | 02:21 PM
  #964
jackra_1's Avatar
Installed the RR upper air intake in car today.
I cut off the rear three fins etc and painted it before installing along with the water/meth nozzle.
Old May 14, 2020 | 09:45 AM
  #965
Tigre's Avatar
Nice !
The Ebay seller must have an identical item.
https://www.ebay.com/itm/06-09-LAND-...0AAOSwADVeQWEn
Old May 14, 2020 | 09:48 AM
  #966
jackra_1's Avatar
Originally Posted by Tigre
Nice !
I saw that however I paid $75 including shipping. However tax on top of that so $79.50 total.
I did some basic measurements comparing my original with the RR intake.
The inlet opening is significantly bigger than my original and there is no elongated upwards bulge in the interior as there is in my original.
Also the narrowest part of my original is wider than the RR.
Originally I did not like the ribbing however I have changed my mind and do like it now.
Old May 14, 2020 | 04:49 PM
  #967
joeleerj's Avatar
Thumbs up Rr air intakr
I've had mine for quite a while, I just bought the coupler and I plan to install this weekend.
Old May 15, 2020 | 05:31 PM
  #968
Sochi2014's Avatar
Originally Posted by Sochi2014
I baught x351 steering wheel for experiments and it looks the same easy upgrade for our cars, the only thing is to correctly reassign resistive buttons and change illumination color from blue to green.
Done
Old May 15, 2020 | 07:34 PM
  #969
joeleerj's Avatar
Sochi2014, THAT LOOKS GREAT!!
I was thinking of doing the same thing. Can you provide wiring instructions for the controls?
Old May 16, 2020 | 04:06 AM
  #970
caldoofy's Avatar
Sochi14 that looks brilliant. Same request as previous poster for more detail 👍.
Old May 16, 2020 | 06:09 PM
  #971
Rancheroguy's Avatar
That is the wood finish all Jaguars should have came with. Fantastic !!!
Old May 17, 2020 | 05:26 PM
  #972
joeleerj's Avatar
Replaced the hood release cable and hood security switch
Old May 23, 2020 | 06:47 PM
  #973
TBoneous's Avatar
Default I spent money on my X358 today!
Old Jun 16, 2020 | 07:48 PM
  #974
PhilBR's Avatar
Default Plugs, Ignition Coils, and more changed
Hi guys ....well, compared to many here, my activity is pretty sedate. But I haven't changed plugs in over 10 years on any car, let alone ever changed ignition coils. In fact, owning this first ever Jaguar VDP has brought out the DIY mechanic in me. I'm not tearing apart the engine, though! :-) Anyway...I changed out the plugs and ignition coils today; tomorrow I'll tackle the driver side. I also replaced the bonnet liner, driver side entry seal and trunk seal. Reconnecting the battery, I was greeted with a yellow light and "Apply Parking Brake" error. Searching on the forum.... I think I can remedy that by following the JTB00084 Bulletin. I hope.
Old Jun 16, 2020 | 08:13 PM
  #975
Pompey's Avatar
Banned
Default Now It Growls
Fed up with the quaint American habit where pedestrians love walking behind cars when they are reversing.....I got rid of the reverse warning alarm ......which incidentally played Home On The Range .......and noticing that my reverse beep beep in my work van is completely ignored as well .........
I installed a little devise that lets out an incredibly loud growl .........sounds just like a big cat growling (mountain lion).........and it’s loud .
Now , it scares the crap out of anyone who is about to emerge from that big *** SUV that always seem to park next to me ......
So now my Jag sounds like a pissed off mountain lion .....
The Jaguar siren wasn’t as scarey as the Mountsin Lion
cool as ......well you know what .....
Old Jun 17, 2020 | 03:10 PM
  #976
jackra_1's Avatar
Where did you get it?
Old Jun 17, 2020 | 06:44 PM
  #977
Mark in Maine's Avatar
X2 where did you get it! Details please.
Old Jun 18, 2020 | 12:11 PM
  #978
jackra_1's Avatar
Did some research on this and came up with the following:
https://www.boomblasters.com/product...horn-wireless/
Old Jun 18, 2020 | 12:56 PM
  #979
Pompey's Avatar
Banned
Yea that’s the one ......go on their website .....they make loads of different ones .......it’s loud
Old Jun 18, 2020 | 07:46 PM
  #980
abonano's Avatar
I changed out my windshield washer fluid reservoir. Old one had a hairline crack half way up that I couldn't seal off.
What a PITA. Front valiance, rim and RT inner fender shield all needed to be removed.
Had to give some "wiggle room" to get the top neck back into the engine bay by removing the mount for the abs assembly bracket and bolts for front fuse distribution box.
Ran the rubber hose straight to the pump as the 90 degree fitting for some reason leaked when connected to the new pump.
And, note to self. Make sure fluid low switch is orientated properly. Had a "low fluid" warning. Thought the switch was bad. It was 180 degrees off.. lol...
All in all got it done.
Now, my wife won't complain about not having windshield washer fluid.
Now, brakes are next!
