Where can I buy just the EBM after air suspension conversion
Old May 26, 2017 | 08:02 AM
philler1's Avatar
Default Where can I buy just the EBM after air suspension conversion
Hi where can I buy a plug in EBM to eliminate my suspension error codes after suspension conversion? Or suggestions??
Old May 27, 2017 | 10:47 AM
Don B's Avatar
Hi philler1,
Welcome to the Jaguar Forums! It's great to have you with us.
The best source for an Electronic Bypass Module (EBM) or similar device would be the company from which you purchased your coil conversion kit. My understanding is that currently the only companies that offer such a device are Arnott Industries and Strutmasters, but I don't know if either company will sell the module separately. You'll have to check with them.
In the meantime, please visit https://www.jaguarforums.com/forum/n...-intro-must-5/ and post a required introduction so we can learn something about you and your Jaguar and give you a proper welcome.
Cheers,
Don
Old May 27, 2017 | 11:32 PM
Panelhead's Avatar
Default I do not know if this works on XJ
I replaced the active shocks on a Suburban with Bilsteins. To get rid of the error codes I stuck a resistor across the two pins on each shock cable.
A 22 ohm 5 watt worked. Measured the resistance with power off.
Old May 30, 2017 | 12:01 AM
Don B's Avatar
philler1,
I have deleted your duplicate thread. Posting multiple threads on the same topic is against the forum rules, which you should read right before you post a required introduction as I told you in my earlier reply.
Cheers,
Don
