Who has the highest mileage XJ8?
Old Jan 3, 2019 | 10:16 AM
  #161
JFNAKI's Avatar
Talking MILEAGE
I have a 2005 Vanden Plas with 151,000 on the clock currently---she is tempermental in the cold weather but other than the quirkiness she runs great.
J
Old Jan 3, 2019 | 12:30 PM
  #162
roviw's Avatar
My 2004 Super V8 is now on 196000, posted on here a few years back when my previous X350 had about 204000 or so.
Old Jan 3, 2019 | 03:30 PM
  #163
Pompey's Avatar
Banned
I agree, I knew more about Jags than the guy I bought mine off and he had already made the mistake of taking his issues to Jaguar......so big bucks to fix.
I knew better and my hunch was correct Phew.
Old Jan 4, 2019 | 02:50 AM
  #164
rtcosic's Avatar
Odometer ticked over the 200'000 mark last week.
I need to replace 2 tyres for the annual MoT (roadworthiness test) at the end of the month. The EPB has been playing up recently and I haven't got to the bottom of the problem yet. I have the usual issue of the wiper parking fault when on Auto or Intermittent. The driver's seat heating/cooling is not working currently.
These minor irritations are awaiting a visit from offspring who are better able to grovel around in confined spaces and can be easily bribed with cheap alcohol from me and cake from Mum.
Old Jan 4, 2019 | 04:03 PM
  #165
Pompey's Avatar
Banned
04 xj8 vp.......142000....bought it two weeks ago.
Excellent condition.
What I’ve done/ found so far.
Restricted performance, codes showing both banks running lean.Found the plastic hose from the round plastic thing on the LHS of the engine had a big split in it. I repaired it with rubber tape and will probably make my own up to replace it with a length of tube and two jubilee clips, as I ain’t forking out 60 bucks to Jaguar.Also found the air filter was filthy so I changed that along with the fuel filter which was the original and was rusty and clogged. The airbox to throttle body was loose so I reaffixed that and put the air box back together snugger than it was. Codes not reappeared in two days now, I would have had a few by now.
Air suspension. Everything looks origonal and appears to be working, although the car does sit lower on rhs, and the other day when I jacked it up I got the car flying too low warning. I turned car off and back on and watched the nose rise.....I think it needs calibrating, or I may just do the conversion anyway and be done with it.
Master door window switch bank switches were loose and sorta worked.....found breaker near me (Long Island) with half a dozen Jags in it. Got a switch for 50 bucks......gonna be at that place a few times methinks. That’s like me having a yard with a junked Jag on it.
Overhead switch for window blind is loose and needs fiddling with to make it work, everything else is good. breaker did not have one but he will call me when he gets his hands on one. That will be 50 bucks as well.
One code I have gotten is the CAN not talking with something else......that seems to have disappeared after doing the fuel too lean repairs.
I have the lurch, very very mild and very very rare........may be something maybe not, new code reader will find more about that when it turns up. Gonna talk to my tranny guy about doing a bottom end gearbox rebuild.
Anyone else’s car play ‘ home on the range’ or something like that when car is put in reverse.......I found the speaker at the back of car on rhs by the lights.....think someone added it. I’ll junk that cos it’s annoying and fit a white noise generator, being in NY we have a problem with pedestrians walking behind cars that are already moving so they can wave their arms at you in a disgusted fashion as though you just tried to run over their kids.So I need something back there.
When my wipers are on intermittent or if I flash them the wipers get stuck on lhs of windshield, when it rains heavier they don’t do that......this one has me befuddled.......it’s as though the wipers are sticking on something but there is nothing obvious. Gonna strip out the motor and see if it is that before I go any further.
Engine cover screws missing........breakers yard.....
Headlights need a refurb.
Clock bulb not working......
I need new hood struts.....every damn car I’ve bought in the last few years have needed new struts.......
Blower didn’t blow any air but you could feel some heat.....just no blow. And when on high the motor would be like having a jumbo jet sitting in the seat next to me. I read up on here about the insulation thing but couldn’t see anything obvious, so I dropped the motor......tricky job.....and I found a birds nest of leaves, sycamore seeds and black and white hair.........the hair worried me.....then with the hood open I noticed the firewall on the rhs was brown and hairy and the opposite side was black.....the black stuff and the brown stuff had been sucked into the blower motor....gotta check out how that happened and figure a way to stop it......gonna realign the whole firewall with air conditioning silver tape ....that should stop it.
Now I have heat I think I may need to flush the heater core a tad.
Trunk will not open with key fob or internal button, Probable fuse issue......
Hand ( finger) brake thing light not coming on, the red one...it did work but now does not.....possible fuse again.
Gonna strip out gear lever as for some reason I don’t like the way it feels.....that may be just me but I’m gonna check to see if I can find anything odd looking or loose.
I need an alignment check, maybe able to do that myself when code reader turns up.....unless I read the description of the code reader wrongly.
I need one wheel lug....may just replace them all and get locking ones......
My leaper feels loose.....read on here about them falling off.....the ones in the breakers yard felt stiffer than mine, gonna check that out and see if I can do something that will prevent it falling off......
So far that’s all I’ve found in the two weeks of ownership.....I had an xjs and an xj12 when I lived in GB, so I know about Jaguars quirks and from experience I know these cars need more than an oil change and tyre rotation every few thousand miles. They need to have preventative maintenance done.....” if it ain’t broke don’t fix it “ does not play well with Jags and will leave you stranded on a rainy night in a bad part of town.....which for me is 10 mins down the road in ms 13 turf......so whilst I’m going over the car any electrical connection is given a coating of dielectric paste, I did that to all my old Brit bikes back in the day and it seemed to keep the prince of darkness from paying a visit.....gimme a few months and I should have gotten to pretty much all the connectors.
In closing I’d actually forgotten why we love driving these cars......it came back to me about 5 mins after I bought it. I am the third owner, first had it on a lease then his daughter had it, so someone Ike me never owned it which is a good thing......it’s in excellent condition and ‘everything works’ as they say in the ads......in my case I know what does not work.......and most are or have been cheap repairs.Spent around 100 bucks so far , 12 for a fuel filter as opposed to Jags 60 bucks , 30 bucks on an air filter and 50 for the door switch......Jaguar quoted me ‘ could be over a thousand’ for the blower to be sorted and they wanted 60 for the plastic hose.The restricted performance thing “could be around a thousand or maybe more”
The body is great with the odd scuff on the bumpers which my body shop guy can fix sometime in the future.
Car cost me 2800 bucks. Registration and ‘taxes’ were a buck fifty.....wink wink.....so I’m into just over 3 grand for an excelllent car in great condition that purrs like it did on its first day out of the showroom......
Major future projects will be the shock conversion and an exhaust that makes it sound like the v8 it really is......but both those can be done at my leisure.....
I promised my gf that I won’t go any where near throwing a super charger at it.......but I didn’t say anything about not buying an xjr or xkr.....but that’s our little secret ok.
Old Jan 4, 2019 | 04:25 PM
  #166
Pompey's Avatar
Banned
Default More
Here’s the birds nest.....there was another chunk this size that I pulled out of the vents....and a ton of dust came out after I’d put it all back together.
Old Jan 4, 2019 | 08:11 PM
  #167
Pompey's Avatar
Banned
Good old Lucas.....without even knowing it they invented the self dimming head lights and intermittent wipers, and the famous fart noise horn.
I well remember the Triumph headlight switch........filled that mother with Vaseline that seemed to do the trick......
Old Jan 4, 2019 | 09:52 PM
  #168
Wingrider's Avatar
Lucas the prince of darkness, & the reason the English drink warm beer.
Replaced all the electrical system parts on my Triumph, with American parts from the local auto parts store.
Old Jan 5, 2019 | 03:37 PM
  #169
Pompey's Avatar
Banned
That warm beer does knock you on your butt though.......the cold beers and lagers are weaker......unless you go for the industrial strength lagers.
Old Feb 16, 2020 | 12:57 PM
  #170
marmar1305's Avatar
Originally Posted by BlackVDP
That's crazy miles...but good to know the 04s will go that far. I hope I drew a lucky straw as well...
Hi, I have an 94 XJ8 and just got 200000 miles on it and running like a dream, no oil using.
Old Feb 17, 2020 | 06:48 PM
  #171
ChrisMills's Avatar
Originally Posted by ChrisMills
June 2018: Let me see...220k miles = 352k km.
I have 84k km so 268k to go. I do maybe 50km pw. So I have 5,360 weeks to go or 103 years to enjoy my car, guaranteed..
I'LL BE BACK in 2121 to claim the prize...plus I get a 25% handicap for having a 6.
Oooh...Feb 2020 I just passed 87,900km (54,600miles) (8.79E+31 yoctometers), so that's 195km/month (121 miles/month)
OMG, what if it wears out?
Old Feb 24, 2020 | 08:58 AM
  #172
wforslund3's Avatar
04 XJR 154k on it. Been a reliable vehicle. Regular maintenance things plus coil packs. Bought at reasonable price and expenses incurred much less than car payment - and I get WOW factor as Jags are not too often seen in West Michigan.
Old Jul 22, 2020 | 01:43 PM
  #173
vysmith1959's Avatar
Default My 2004 XJ8 w 191,000 miles still runs well!
I was rear ended a week ago and need a quarter panel and rear bumper and lights. While I’m at it may as well fix the AC and replace the windshield. I hear some cranking while turning the steering wheel. From time to time the transmission jerks me. Planning to invest 5K in repairs and cosmetics as I think it will get to 250k! I’m going to roll the dice and hope for the best! I love my car!
Originally Posted by trosty
My 04 XJ8 has 150K miles on the clock.
It runs well with the odd engine hiccup every now and again.
Spurious little issues like leaky driver foot well, once after using a automated washing machine, won't be doing that again.
One rear window won't work properly sometimes from the drivers door console. I have stripped, cleaned and put back together ( an easy job to be honest), but still the same. I have even carried out the reset but no joy.
Interior is still nice and clean ( except a little sagging of roof liner on the rear pillars. Sunroof cover is hanging loose too.
However, I got the car for a song, am happy to put a couple of thou$ into it to keep it all mechanically sound and would expect it to pass the 250K+ miles no problem.
Old Jul 29, 2020 | 09:59 AM
  #174
thunderwood's Avatar
2006 XJ8L 205k+ miles....lots of driveway work, struts, control arms, bushings, coolant hoses and tanks....full time job keeping it on the road, but there is something about an XJ! It's ALWAYS just one repair away from perfect!
Old Jul 29, 2020 | 05:37 PM
  #175
meirion1's Avatar
Tell us again what's wrong with the blower that needs a $1000 fix. lol
Old Jun 12, 2021 | 02:44 AM
  #176
97kid's Avatar
Jaguar xj8 2002 179,677 miles run like brand new
Old Jun 13, 2021 | 07:27 AM
  #177
Petz's Avatar
My first Jag 4,2 2003 have been driving it almost every day since the purchase in december 20. Lots of cleaning ,polishing ,reajusting of carpets , loudspeaker replacement , batterrie, oilchange ,renew brakes, maf cleaning, light bulbs, selfmade grille, trays cleaning and fixing She loves the care an runs fine ,very responsive, comfy drive, 333000 km/206000 miles.
Old Jan 28, 2022 | 11:45 AM
  #178
92/93 XJS's Avatar
You guys need to DRIVE your cars! Over the past 3 decades I've not moved on to replacing my "driver" until the clock passed 200K. Currently (1/22) I have my 94 XJS at 215K. The latest addition is an '01 XJ8 with 155K, replacing an '05 XJ8L that got totaled at 235K. I fear the '01 will be my last Jag since I'm now retired and over 70, lol.
Old Jan 29, 2022 | 10:23 PM
  #179
Sentinelist's Avatar
Great to see big numbers on these cars and that they're capable when well maintained.
Understood, sir. Mine is a 'third car' I'm hoping to keep under the 100k mark for the duration of my ownership due to its rarity but I'll be damned if I don't get behind the wheel at least once every two weeks at least for its own health. Still trying to figure out that fine line of balance as it's not the daily driver, but not a garage queen either. And I'm still working from home for the foreseeable future.
Old Jan 30, 2022 | 09:57 AM
  #180
Wingrider's Avatar
The total mileage to me is not that much of an issue.
Both of mine were purchased before the 100,000 mile mark.
Both in decent shape, with the typical known issues
They are supposed to easily go three times that mileage.
Paid about 10% of the new car price, with 2/3 of the cars life left.
With two in the garage, both of us in our 70's.
They could easily out last both of us.
The 96 Honda grocery getter may need replaced though .
