XJ8 oil
Old Apr 9, 2012 | 05:08 AM
Tomipl's Avatar
Default XJ8 oil
I just got my first Jaguar. The XJ8 have 82000 mil.
I'm wondering how often you guys do engine oil changes on the car. Every 3000 miles or more? And also what kind of oil to use. Regular, syntetic or hafl syntetic. And what brend you prefer.
I know the car was service in dealer before I bought it, but I like to do oil change and filter change by my self.
Thank You
Old Apr 9, 2012 | 10:44 AM
SuperTrav's Avatar
First of all, congratulations on your purchase and welcome to the "club"!
Look, oil change intervals and type is the oldest saw known to "car people"!
You WILL get so many different opinions here, and everywhere, in cardom that it will confound you. SO, go with what you think is best.
But since it looks like I'm responder nubmer 1, I'll give my $.02.
I decided to change the oil every 5K, and have gone with what the manual recommends: Castrol CONVENTIONAL oil, with the specification that most closely matches the API requirements the current oil's specifications meets or exceeds.
Happy motoring!
Old Apr 9, 2012 | 04:06 PM
XJL's Avatar
XJL
Since I currently drive my Jaguar only once a week, I change the oil every 5,000 miles or once a year using Mobil 1 synthetic oil. This is what my mechanic thought would be the best.
Old Apr 9, 2012 | 09:25 PM
donch61's Avatar
As SuperTrav said... everyone has one....
this is the best..
SAE 0W-30 Signature Series 100% Synthetic Motor Oil
Product Code: AZOQT-EA
http://www.amsoil.com/catalog.aspx?code=AZOQT-EA
Old Apr 9, 2012 | 10:24 PM
solerydr's Avatar
Corn syrup. All the cool kids have switched to it.
Old Apr 10, 2012 | 02:45 AM
Fraser Mitchell's Avatar
Oil change interval is every 10,000 miles or yearly, so cars not used much should have the oil and filter changed every year. Always remember, oil is cheap, engines are expensive.
And, of course, always use oil to the Jaguar recommended specification, (or better if you want to). Basically, most well known brands of 5W-30 are OK)
I've just gone into the garage and looked at the litre of top-up oil my local main agent gave out at the last service. Its Castrol Magnatec A1 5W-30 with the following specs API SL ILSAC GF-3, ACEA A1/B1. Meets Ford WSS-M2C913-A and WSS-M2C913-B.
Actually I hardly ever have to top up between services, so now I have two containers of this oil !! I use it for the carburettor dampers on my MG Midget
Old Apr 10, 2012 | 09:16 AM
edobernig's Avatar
Default Refer to XJ FAQ section for help
Oil and filters are very controversial. However a oil change around 5,000 miles or a year is reasonable. Please refer to this procedure posted in XJ8 FAQ's it will help you with about everything you need to change it yourself. Its easy!
https://www.jaguarforums.com/forum/x...-change-67711/
Old Apr 10, 2012 | 10:16 AM
freebeeme's Avatar
I'm from the netherlands and use kroon oil asyntho 5W30,
which exceeds the requirements of the advised oil.
I change oil and oilfilter every mid november just before the winter kicks in.
At the same time i change also the airfilter.
And used slick 50 oil treatment.
All this made the car run better and it uses less fuel than before.
I only use gasoline with an octanenumber above 98 and add 0,5 percent acetone to it.
Which really make a big difference
Used acetone to my last car a volvo v70 t5r with rica tune for 6 years without any problems.
Makes my car engine run better and uses 10% less fuel than without acetone. (under same circumstances)
Old Apr 10, 2012 | 11:10 AM
Tomipl's Avatar
Thank You for help. I would like my car to run for long with out any problems because I LOVE THR CAR. My wife wants XJ8 too. So probobly soon Ill shop for another one.
tomsjag
Jun 10, 2023 10:02 AM
Scarecrow
Mar 28, 2016 03:17 AM
mls0036
Oct 17, 2015 10:03 AM
ratgawd
Sep 16, 2015 04:15 PM
AtholC
Sep 9, 2015 09:07 PM
