XJ8 Rear Seat Removal
It's me again (Margaret).
Just noticed that the latch for the middle seat belt in the back seat is fallen beneath the rear seat. I tried the "push back-lift up" method common for most U.S. cars, but it didn't work. I've done Google searches, and searched the archives of several Jaguar forums, but couldn't find how to remove the rear (bench) seat cushion in a 2004 XJ8. Please help. Thanks in advance, Mitch |
I don't know if we are the same, but I have an '06 XJR....feel around the lower front edge for some plastic triangler shaped "fingers". If you find them, try to move them either left or right. They are latch releases (4 of them). If they won't move, put a little downward pressure on the seat at the same point as the latch. Once you have released all 4 latches, lift the front of the seat up to unhook the rear. Be mindful of any wiring for heated seats or whatever. Hope this helps Bro.
Originally Posted by MarlboroLTS
(Post 123425)
Rear seat removal - 2005 XJ8L
Anyone else successful in removing the rear seat on an 2005 XJ8L?
I have re-read the above and retried to remove the back seat but am unable to move the 'fingers' left or right. Am I missing another bit of info? EDIT: So, should I be feeling for the levers/latches through the leather or reaching behind and up the seat foam to find the release? Thanks- |
It is in fact damn difficult on some cars. The key is downward pressure on the seat as you pull the latches down. I had to get the dealer tech to walk me thru it the first time but it is still a 2 man job for me.:icon_razz:
Tarheal-
Thanks for the response. I will enlist a second set of hands and give it another go. To clarify, am I reaching under/behind the foam edge of the seat, or should these release latches be able to be reached and moved through the leather on the 'face' of the seat? |
They are under the seat of the edge that faces the front of the car, by your feet.
I am in the same boat. i bought a 2008 XJ8L and am missing the middle seat belt attachment. I have playd with taht seat for an hor and cant get the middle to release !
RRGGG ! |
thanks for the info on how to do it- I will have my 7 year old sit on it while I try and release it again,
4 Attachment(s)
Here ya go! Helps to have little fingers.
https://www.jaguarforums.com/forum/a...ine=1358990152 https://www.jaguarforums.com/forum/a...ine=1358990152 |
thanks- that was so nice of you to post that.
Jag XJ8...photos were a HUGE help with my rear seat back disassembly. If I could have given you 10 more thank-you clicks, I surely would have. There is no way I would have gotten my seat bottom removed without knowing what I was looking for and where.
Hey, what strikes me is that in the original post from 2009 $1.74 was enough for a gallon of premium!
:icon_eddie: |
Originally Posted by Jag XJ8 Red
(Post 662645)
Wow, thank you! Only your video really clinched it. I did it in 15 minutes. Thanks!
I agree. This was very helpful. Sometimes something that seems obvious to someone isn't obvious to everyone.
If a picture is worth a thousand :icon_pics:...then a video is worth a million "attaboys" :icon_clapclap:. Thanks again! |
And if you need to remove the rear bench just pull the two cloth pulls hanging under the base of the rear bench. They look like seat belts minus the latches but you pull each then pull the bench out.
Took me a while to figure out on a 2005 VP breaker vehicle. |
Rear bucket seat removal 2006 Xj350 super v8 Portfolio
Anyone have tips on how to remove the rear bucket seat bottoms? Am I feeling for the same triangular levers as in a bench seat? Makes sense that the hardware on body is the same regardless of seat fitment. None of seat controls on side - recline, headrest and lumbar - are operational thus I’m assuming it must be switch. The memory buttons on the door will move the seat ever so slightly. The seat switches on the other side are fully functioning. Can the seat switch be removed without removing the seat bottom?
Originally Posted by Nautivan
(Post 2474675)
When my electric rear seat on one side was not working when i first bought my 2004 Super v8 i also thought it may be a switch, however it was sorted by the dealer doing a software update ! no need to renew the switch after all. Sometime electronics in cars can be like a computer, turn it off and on again, I dont know whether a hard reset ( disconnect battery for a while and the reconnect ), may help you. |
Unintended consequences of hard Re-set
Thank you Roviw. Are there potential untintended consequences from a “hard Re-set?” In other words, is there any known reason I should be reluctant to try this?
