XJ8L Valley Hose Replacement Parts
Not sure from memory, could well be - but there are also fixings on the inner edge; I only remember that mine appeared obvious - Their function could only be to secure the two halves (aluminium and plastic) of the Manifold together?
Incidentally, (apologies for being somewhat premature) but when you refit your Manifold, make sure you pull the wiring harness at the back up and out of your way, so that it does not become trapped under your Brake Booster Pipe.....
Use this link (which I gave you in my first post numbered 4) to Michael Hamilton's post; if you scroll down, you will see that Michael was sent the wrong hose at first, and he corrects this and posts a picture and the correct part number further down (his post numbered 7)? Check your hose against his picture and part number...
https://www.jaguarforums.com/forum/x...on-s-c-149873/
#30
#31
#32
#33
Hi all,
My 05 xj8l has 210,000 miles and sprung a major coolant leak. My mechanic pressure tested the system and thought the leak was coming from under the intake manifold.
in the quest to save $900 in labor costs, I’ve decided to attempt this job myself.
I could not find a detailed step by step thread for N/A 4.2 x350s, but I’m pretty sure these are the parts I’ll need:
Under Intake hose AJ811763
TB Return hose AJ89554
rickpwilson
08-20-2020 10:08 AM
daro31
10-18-2017 08:22 PM
guyslp
09-12-2013 07:29 PM
