XJR running a little rough after Mina CAI
I've had the Mina CAI for about two months. Last week, I started noticing the car was running a little rough and immediately I got a CEL, code P2676, air cleaner inlet control circuit low.
Any chance the CAI caused this? Am I looking at replacing the MAF Sensor? Part#2w93-12b579-ag.
Can it be cleaned?
I'm thinking about putting the stock air box back in.
Thanks,
Can it be cleaned?
Thanks,
Sounds like that code pertains to the air inlet flap at the bottom of the airbox. I assume you have an electrical connector that isn't doing anything now that you don't have the stock air box in there?
If the stock airbox with the flap is not there, then the only thing you can do to clear the code is put the stock airbox back in or rig up the flap so the electrical system going with it thinks it's still there.
So I just drove the car for a while after cleaning the MAF sensor and changing the Mina CAI cone filter for a Dryflow Cone from AEM which provides better filtration and I didn't notice any rough idle, etc.
Not sure if the MAF cleaning and the better filter had anything to do with it.
Also, yesterday was pretty humid and rainy.
BlacXJRcat (07-29-2017)
That is exactly why I removed the "el cheapo" Mina filter and installed a Dryflow AEM cone. Luckily I had a reducer flange from a CAI is bought for my Grand Cherokee which I took off two days after installing it. Didn't like the sound. Anyways I was able to install the AEM which was something like 6" ID.
I've had the pulley sitting in my garage for the last two months. I have to install it.
