zenon Headlight
I've not seen lenses available for the Jag. You could try removing the broken lens from your car first to see if it is even possable to remove without damaging it. I watched a youtuber remove the cloudy lenses from a Lambo murcialago, thats not spelt right, and he broke them. You should have seen his face when he found out they were £10000 each! and yes that is 4 0s! You will probably be best buying a second hand unit.
