1996 xj AC tensioner bearing part number?? HELP!
Hey Ive been searching EVERYWHERE and cant find a new Air Conditioner Belt Tensioner bearing. I fell into the sewer and no place will pull out a couple bearing for me to help identify the right bearing. If anyone can help me find a new bearing for my 1996 xj6 they will rock. ok just inside/outside diameters. so i can go to a bearinf store and get one.
the number for the pulley itself is NBC5012AA I cant see it on mine but i pulled this number off jagbits.com
http://www.jagbits.com/mm5/merchant....300_Climate_10
Dimensions?
can you please measure in inside ring and outside ring for me. The pulley cost almost 50 bucks at the dealership and I bought a pulley already thinking i just need to pb blast the rust off the bearing but it fell in a sewer..long story? how many miles you got on your xj6, what color?
let me look for a tape measure and i will run out and have a look....I have a black xj6 .. it has 189thousand km on it..I just bought a wrecked XJR tho it is brit racing green and 74 thou km on it .. so i am doing a full swap inside and out.. suspension and all... not sure what miles that would be... I will do my best to get you the measurements.. worst case i will pull my pulley off and check the bearing gimme 10 min
napa sucks
napa workers are lazy asses. i called locate ball bearings in cali, and this guy is looking for the size, turns out hes a on old jag too. i drew the dim out on paper and thats the size for sure. I live in the states, i wouldnt mind having you sent me that bearing but thats prolly too much of a hassel.
if you cant find it it isnt a hassle at all.. i can send it to you ground mail and it would be there in 3 days tops.. i am in Ontario, you are in NY not that far.. or can overnight it.. i have the fedex kiosk right behind my house.. just pay the shipping if it comes to that.. i wont need it...i have a whole car with a whole engine etc coming
buffalo bearing
hey I found an ATV bearing at buffalo bearing 3$ and thanks so much bro, that number you gave me was the break i needed. I feel like i solved a case that i've been working on for months. but now i got a new problem maybe? The ac is spinning and more cooler air is coming out than usual but its not AC cold. The ac hasnt been turned on in 3 years and an thinking its needs freon refill. Do you know how to DYI or should i just get the dealer to do it if its cheaper than buying the refill kit?
RoyLittle0
05-25-2023 02:38 AM
