1997 XJR gear selector linear switch
Old Mar 18, 2013 | 03:28 PM
Jagxjren's Avatar
Default 1997 XJR gear selector linear switch
HI everyone, im after advice on how to adjust the micro switches on the gear selector as they a playing up, the car turns over but will not fire even with slight movements on the the selector.
Old Mar 18, 2013 | 06:41 PM
robxjr6's Avatar
Hi, if your car is 'turning over' it cant be your switch.
worth checking for fuel at the rail & a good spark.
Crank sensor failure seems pretty likely, I carry a spare in my glovebox!!
Old Mar 18, 2013 | 08:08 PM
Doug's Avatar
Yeah, I agree. I took a quick scan at the schematics and I don't see any from the linear switch that would cause a "cranks but won't start" condition.
One clue on the crank sensor: if the tach needle doesn't jiggle a bit when cranking, the fault is probably the cranks sensor
Old Mar 19, 2013 | 01:55 PM
Jagxjren's Avatar
Thanks robxjr6 and Doug for that information and i will check the Crank Sensor. Some more light on the situation is when turning the ignition too positon 2 the " P " on the selector does not light up and the when the gear slector is in normal P position it does not do anything, yet pulling back on the selector engages the the switch and the car begins to turn over. I have read on here that it can be caused by the Linear Switch and some gental re-alignment can resolve this, which is why i was aiming in that direction of a possible fault. Thanks Jagxjren.
Forcedair1
Sep 8, 2025 01:57 PM
tomsjag
Jun 10, 2023 10:02 AM
user 652867429824
Oct 28, 2015 10:18 AM
Doovoe
XJ40 ( XJ81 )
Sep 6, 2015 10:54 AM
arnoldmilk
Sep 3, 2015 07:42 PM
