97 xj6 4.0 crank no start no spark
My first post. Please soneone help me having issues with a 97 xj6 4.0 i bought yesterday. Was a no start from the door but i got it for 300 bucks so i didnt really care what it is. I charged up the battery and cranked it and it actually ran very rough for about 2 mins . I then scanned it and got code p1775. i seem to be intermittently getting no spark and hav replaced the crank sensor so far. I hate throwin parts at shitt for no reason but i was sure that was the issue. Now i get no starts at all and no spark. I am getting cranking rpms on the dash and the new crank sensor is ohm in spec. Although i am only getting 2.7 volts at the ckp sensor circuit. Could this be a bad ecm?! I already swapped relays . Please somebody point me in the right direction. |
https://cimg7.ibsrv.net/gimg/www.jag...a828be459f.jpg
Watch the volt meter that it does not drop below 11.4 volts during starter rotation Below this voltage the starter will rotate the engine but be below the voltage to properly run the ECU / spark The instrument gauge is very accurate There are 2 relays that power up different sections of the ECU , on is the small one on the corner of the RH engine fuse box you can swap with the LH engine fuse box ( LH is really just the horn relay ) The second large relay is the ECU controlled relay called the X that is enabled by the ECU to bring power back into the other section of the ECU To bypass the CKPS and ECU control of the # 1 fuel pump relay you can jumper https://cimg1.ibsrv.net/gimg/www.jag...fdbc84955f.jpg |
Thank you for your reply. I know that i have proper cranking voltage because i have a very powerful jump box . Also where is this 2nd relay for the ecu . I have already swapped the one relay with the horn relay. Also i have 12 volts at the cam sensor. Not the crank tho? |
See page 50 then back to 49 for the wring out page on the CKPS
Black 23 and Black 26 does not get a reference voltage from the ECU http://www.jagrepair.com/images/Auto.../jagxj1997.pdf As you saw your fundimental reading on the inductance CKPS is 1300 ohms , the funtional reading is a sine wave with a frequency dependent on RPM The Camshaft position sensor ( CMPS )s a 3 wire hall effect sensor that by design is not needed to start engine It has a basic power source and not a reference voltage source My computer was going nuts last night so let me clean up the last nights post while shoveling driveway https://cimg0.ibsrv.net/gimg/www.jag...b58eaae3f0.png https://cimg9.ibsrv.net/gimg/www.jag...db30f3ddae.png |
Thank you i will try . And all data gave me a crappy version of this. Also i had no idea the main beam was an ecm relay *♂️ Smh. And is ecm failure common woth these ? |
Main beam and fog relays are swapping options
The most common problem with the X300 is my laptop |
