cam cover corrosion
Old Aug 7, 2011 | 06:48 PM
EZDriver's Avatar
Smile cam cover corrosion
Is there a solution to the continuing corrosion of the spark plug wells in the cam cover on my 1995 XJ6? Will they eventually corrode through? The car has 110.000 miles on it and I really love it and want to drive it for a very long time.
Old Aug 8, 2011 | 06:18 AM
Straight6DOHC's Avatar
Yes, they will eventually corrode through. I reckon your coil/s will be arcing a spark to the cam cover which accelerates corrosion. Look for cracks in the coils. Have your cam cover painted. I've heard varoius suggestions over the years about how to insulate coils or prolong their life. Some suggest using the more modern spark plugs and fitting a rubber sleeve over the coil.
In the first instance, check the coils for cracks.
Rivguy
Nov 13, 2022 02:55 AM
Davidvdm
Oct 7, 2015 03:18 PM
Dickie_L_J_O
Sep 13, 2015 07:44 AM
jagent
Sep 12, 2015 09:10 AM
jaggermang
Sep 8, 2015 07:07 PM
