Center console and door lighting going out over bumps.
My door switch lighting on both front doors and my center console lighting go out and come back on simultaneously when I hit a bump. Any advice on where to start or a wiring diagram that I can locate a likely plug or ground that is going bad?
Before I forget a X300 came into a salvage yard Thursday that may have a original alternator for the taking , I didn't look at it as was looking at other things .
Now back to your lights See page 92 or abouts Is there a group of lighting in the print that matches your issue ? I see a single bulb center consol switch pack and a driver and pass door switch pack , is that the area of interest ? They have different grounds so that rules that path out By putting the small dimmer knob on the steering column to override does that make a difference as you test drive it ? http://www.jagrepair.com/images/Auto.../jagxj1997.pdf :icon_playing: Bed time now |
You need to clean and tighten the grounding stud on the back of your head unit.
https://www.jaguarforums.com/forum/x...09/#post338514 |
Originally Posted by Lady Penelope
(Post 2015430)
They have different grounds so that rules that path out By putting the small dimmer knob on the steering column to override does that make a difference as you test drive it ? Thanks for the help and ideas!!! |
