Coolant Light
My coolant light is on, however when I check the level it's fine........no blown fuses either anyone have any idea why the light would be on?
If you do a search you will find many threads dealing with this. The float inside the reservoir may be stuck or have sunk, or the connector on the bottom may need cleaning.
