Correct idle RPM when in gear?
Curious what the correct idle RPM should be when the car is in gear.
It idles between 700-800 in Neutral or Park, and drops to about 600-700(closer to 600) when in gear, so just checking if that is what is expected. . |
Originally Posted by Lady Penelope
(Post 1854973)
Per the document, which BTW is a VERY helpful reference: Target stable idle speeds: Park / Neutral – 700 rpm (normal operating temperature) Drive / R, D 2, D 3 – 580 rpm Idle speed ± 30 rpm when coolant temperature is less than 86˚F (30˚C) Idle speed ± 20 rpm when coolant temperature is 86˚F or higher |
Isn't 4.0 and 3.2l different when it comes to idle RPM? As far as I remember they are, 3.2l should idle slightly higher than 4.0. Mine definitely did.
