Differential Oil?
Doesn't mean much as long as its the right specs
I use redline shockproof heavy in my XJR6
I also had my LSD shimmed and a machined spacer made to replace the crush tube as well as gear change on my XJR6 all done so the diff could be thrashed LOL
On my new X350 and my first Jag a XJ40 I just changed the oil every 2 years
With the XJ40 I used mineral oil in the X350 I use synthetic the XJR6 I used redline shockproof heavy
belawidi (05-20-2014)
Diff oil
2 litres should be fine , or at least was for me
Just make sure you can get the filler open before you drain or you've had it
Method seems right - fill until fingertip soaked or overflows
And be aware, it's a beggar to fill - large syringe and/or hose will definitely help as it's just plain awkward
And drain carefully as old fluid will likely be horrible
chris
chris
Craighead (06-04-2014)
Received 10,756 Likes
cool (06-07-2014)
The difficult to find large syringe can be replaced by an easy to find, and more practical, pneumatic cylinder, the cheapest you can buy from the market. No need to be double end cushioned/magnetic,etc., etc.
They come in certain piston diameters and variable strokes.
A 63mm diameter and 160mm stroke cylinder, has a volume of ~500cc (498.75cc)
The thread to attache your fitting-hose is 3/8"
The fittings also vary, so you can attache the hose (diameter) you want
So, you can suck the fluid-oil from it's tank (or the steering system's oil from the reservoir, or whatever has to be sucked out) the and press it where you want, easy.
Attached is an example of one brand, there are a looooot of pneumatic brands
About the oil: Lubrication Engineers has oils, i use them wide, car (engine/gearbox/differential), motorcycle, factory, no problems, very long runs, you can send them samples, so you have e feed back of your condition.
Check the attached JPG file, it's a simple pump, made out for ~80 euros, all fittings are "push in" type, you can change the configuration and hoses diameter, any time.
With the above described cylinder/pump i drain ~50lt marine engine's oil in ~5 minutes, you can drain much more water in much shorter time from the boat if you are in real trouble also....
Hard to find large syringe? Try ebay as loads available
That being said, I bought a selection of sizes from local chemist, but did explain why I wanted them - they were most amused when I explained it was for a brake fluid transfusion!
Smaller syringes are handy for squirting oil or cleansers in tight corners / spots - a selection of various diameter clear hoses also help in tight spots
Also useful for draining brake and ps reservoirs when replacing hoses
Syringes and hoses of various sizes - 'don't let your toolbox be without them!'
chris
chris
FS[MidAtlantic]: 1997 XJ6 VDP $3,900 - Very RARE Anthracite on Warm Charcoal
42Ajd
09-26-2015 07:04 PM
Woznaldo
09-26-2015 11:02 AM
