Source for washer nozzles?
The following 4 users liked this post by SNG Barratt USA:
I managed to find a set for mine but was considering the alternatives to the Jaguar ones.
Honestly there are dozens of different types out there that would work just fine. If you look around on ebay or better still, get a chance to go to a wreckers yard, I bet you could find something that would work perfectly in 10 minutes. It's just a dual nozzle that accepts a rubber hose. They are no big deal.
Other nozzles may fit but they won't fit perfectly. Then there's also the issue of the connection for the heating element built into the nozzle. If you live in an area where you don't get cold temps then that's optional.The main problem with fitting different nozzles in place is that the original factory nozzle is held in place from beneath with just the tension from the nozzle housing (clip?).
