Front Suspension Coil Spring Red Painted Line
Hi Everyone
Good Morning and I have a question re: MY 97 xj6 front Spring Coil appears to have a painted red line running across the spring. Does anyone know what it's significance is? Thanks Folks BigBoss in Dallas TX :icon_call: |
Interesting question, I have no idea, but also am curious if there is any significance.
Generally speaking those types of paint stripes are used for parts identification on the assembly line
Cheers DD |
Was curious if they were perhaps some indicator of a different spec spring.
Originally Posted by al_roethlisberger
(Post 971595)
Rather than looking at codes or part numbers when grabbing parts to assemble a suspension an assemblyman knew that (to make up an example) USA market XJRs got springs with one yellow stripe, ROW XJRs got springs with two blue stripes, a base XJ6 got springs with no stripes, etc. Cheers DD |
Doug
Thanks for that insight....... That makes sense..... I'm about to replace the front shocks this weekend. So wish me success. BigBoss in Dallas TX |
Originally Posted by Doug
(Post 971604)
Virtually assured, if my assumption is correct.
Rather than looking at codes or part numbers when grabbing parts to assemble a suspension an assemblyman knew that (to make up an example) USA market XJRs got springs with one yellow stripe, ROW XJRs got springs with two blue stripes, a base XJ6 got springs with no stripes, etc. |
If your car still has springs with these stripes on, they probably need changing as they are the original ones from factory and thus 17 odd years old
Thanks again guys for that insight....... at least something is still original
on my cat......... The only "touring" I do now is to and from the grocery store, airport and and the local watering holes..... So I guess the springs will stay :icon_lol: BigBoss Dallas |
Originally Posted by dfieldsend
(Post 972122)
That being said, is there some consensus that the regular XJ or XJR springs do need to be changed after 15ish or more years? I haven't noted that as a common recommendation in the threads here yet, but... Al |
(Post 972227)
Not that I'm aware of. The only objective determination I'm aware of is to measure ride height. If your car has a bad case of the droops, change the springs. This might be more critical on X300s than other cars since there's is no camber adjustment...but I'm not aware of X300s being unusually hard on springs or replacing them as a matter of routine. Cheers DD |
Doug
Thanks for that input....... That sounds like the only way to be sure about the springs. Though I can't imagine my replacing them yet since I do very little driving these days......... The front shocks need replacing and I plan on doing that today, so wish me luck :icon_rally: BigBoss in Dallas MY 97 XJ6 |
