Gear shift lever queries
Old Apr 28, 2022 | 05:56 PM
Spud Maat's Avatar
Default Gear shift lever queries
Ok so a couple questions regarding the gear shift lever.
so i noticed 2 things.
when i put from drive into reverse the reverse light is not always coming on.
My trouble shooting shows that the gear lever needs to move just slightly up past reverse to turn the reverse light on.
and also with park sometimes park is not properly engaging.
seems to me that the likely situation is that the gear shift surround needs to move up slightly so that the stick is moving slightly higher when it slots in.
just seeing if this makes sense to others and if people can follow what i mean.
as it just feels to me that its slightly out of allignment
Old Apr 29, 2022 | 02:45 AM
b1mcp's Avatar
The signal for reverse, park etc comes from the gear selector module. It's the black box at the bottom of this picture. It's more likely that this needs a tweak for alignment.
If you look at the mounting screws you can see the module has slotted holes for slight adjustment.
Old Apr 29, 2022 | 02:49 AM
Spud Maat's Avatar
thanks.
just those two screws that can be seen in the pic?
looks like a little pain to get to...
hopefully my right angle screwdriver can get in there easy enough.
i would guess i need to move it down (toward the rear of the car a little).
Old Apr 29, 2022 | 02:44 PM
b1mcp's Avatar
Yes just those 2 screws IIRC.
A small 1/4 hex bit ratchet is your friend for this kind of job.
Old Apr 29, 2022 | 08:15 PM
John Herbert's Avatar
To quote my previous post 6/1/21 -
Typical unthinking English engineering with the linear switch - Two Phillips head bolts in a position not easily accessed by a screwdriver, not even the angle type.
My simple solution replace them with suitable hex head bolts for much easier access with a spanner.
John Herbert
(1996 XJR)
Old Apr 29, 2022 | 10:28 PM
watto700's Avatar
Gday Spud,
These attachments might help though I have no idea of the dimensions of the setting plate.
Cheers,
Jeff.
File Type: pdf
File Type: pdf
Old Apr 29, 2022 | 10:44 PM
watto700's Avatar
This might also help.
Cheers,
Jeff.
Old Apr 30, 2022 | 01:08 AM
Spud Maat's Avatar
thanks for the help guys.
it looks like the problem i have is actually the lever adjustment.
there is a little play (wobble) in the lever,
and the point at which it clicks into revers is actually sitting higher than the notch.
the linear switch appears to be working fine as the housing illuminates correctly.
but if coming up from N into R the lever actually needs to go above the notch for R for it to engage.
it looks like a bit of a pain to get in and adjust all this stuff.
should be able to see what i am talking bout at the end of the video. (sound on you can hear when it "clicks" into gear)
Old Sep 6, 2022 | 01:56 PM
RedSky's Avatar
I've never had to adjust a Linear switch, the mounting holes are pretty limited in giving you much movement.
Adjusting the selector cable is the most common fault.
Loosen the lock nuts on either side of the mounting bracket and slide the cable fore and aft until the lever slots
into the detent in the gear shift surround for R D and N. Then tighten the lock nuts.
Old Sep 6, 2022 | 03:28 PM
Parker 7's Avatar
There is a upgraded part # on the linier switch for whatever reason
Genuine Gear Change Control-automatic (automatic) For Jaguar Xj 1995 - 1997 (from 720125 To 812255) Classic | Jaguar Land Rover Classic Parts
the switch can be opened and cleaned with a pencil eraser , fluid intrusion area
There is an adjustment on the different rotary position sensor with the 4.0 liter engine if you have the 4.0 and it's different transmission ( ZF4HP22 vs. 24 )
Will have to double check where the reverse light is triggered by
Old Sep 6, 2022 | 09:31 PM
xalty's Avatar
i forgot how the jgate even works on the 3.2
xj40 guys probably have more in common
Old Sep 6, 2022 | 10:12 PM
Parker 7's Avatar
On paper Ref page 112 of the 96 wire guide
The reverse light is triggered by the linier position switch for the 4.0 , 3.2 , V12 and 4.0 SC
there is a given wire path through the lamp control module
Note that it passes through the BT4 connector above the fuel tank
This is for the one exterior lamp control module IN THE TRUNK version
tHERE WAS A FUSE UPSIZING tsb AFTER THE CHANGEOVER POINT GOING FROM TWO TO ONE MODULE
15-16 (jagrepair.com)
WAS YOUR THE ONE OR TWO LAMP CONTROL VERSION ?
pAGE 99 OF THE 95 WIRING GUIDE FOR A TWO EXTERNAL LIGHT CONTROL MODULE VERSION
jagxj1995.pdf (jagrepair.com)
Early 95 is also triggered by the linier position switch for all engine / transmission combinations
Biff Baxter
19
Feb 28, 2018 03:20 AM
Mac Allan
Apr 15, 2017 02:27 AM
rwold
Jul 24, 2013 08:34 AM
rvaha
Feb 5, 2012 04:12 AM
