help! - photo of Manual XJ40/X300 manual gearbox mount
Can anyone please help me with a photo of the rear gearbox mount for a manual car? preferably X300 XJR with the Getrag 290 gearbox
My car has failed it's inspection because the Govt in its infinite wisdom has changed the rules 3x in 12 months and my XJR is now classified as a 'modified vehicle' because it was originally an auto but is now converted to a manual In the past 3 days I have been bounced around in circles from the inspector to the certifier and back to the inspector again, who seems bewildered and scared of liability if I have a crash. Health and Safety gone mad Anyway, to get around all this mess, I probably need to source new manual brake pedal and clutch pedal and fit these to my pedal box. I also need to try to prove the gearbox is properly mounted. There is an aluminium ladder frame bolted across the rear end of the Getrag box, with two long strips of 1/4" steel bolted to the chassis rails as 'spacers'. This may well be factory standard, given the manual car was low volume. Can anyone oblige me of a photo or two of their factory manual rear gearbox mount? thanks in advance... |
Al,
No got snaps, dont even know of a manual car hereabouts. Maybe this link will assist a bit. The 3.2 and 4.0 manual cars have the same part number for that crossfarme. The R crossframe is a different number, BUT, it only lists the R as Auto. The rubber mount appears the same number, but on this one the R is a NO mention??. Engine Mounting Bracket-Rear-3.2/4.0 Litre - Parts For XJ Series from (V)720125 to (V)812255 (X300) | Jaguar Classic Parts AU |
thanks Grant
Ive since talked to Ray the previous owner the 2 long strips of steel between the transverse mount bracket and chassis rails were added by him to improve the driveshaft angle off the back of the gerarbox, and to strengthen the mounting area . Apparently no extra holes were drilled so it should not be a problem |
Hi! Unfortunately I don't have a place where to shoot it from below, this was taken in a hurry during the registration technical checkup. It's a Getrag 260 thou. https://drive.google.com/open?id=0B9...lhPRWZ5MDZJYXc
thanks Fahrenheit for the pictures
they may prove useful to show the certifying engineer who has to sign off my car |
