I need new ignition coil wires
I just paid an extra $45 (in additional to the base $10) to get one day shipping for a lower radiator hose that only cost $38. Very little shocks me when it comes to price and what we're forced to pay if we want convenience. I need/want to drive my car so I have to be willing to pay that extra money.
For the ignition coil wires I suppose I'll start by getting some old connectors from a salvage yard so I can make the switch with my 'new' wiring harness as quickly as possible. Now I just need to run to the shops and get some spare time.
Sorry.
I'm about to buy a full set of coils for $450 and I want to do new plugs and everything else in the ignition system. I want it all new. I didn't mean to be lazy. Basically, I'm checking what all do i need - Coils, spark plugs, what else?
Do I need these?
More Information for DENSO 6716295
Thanks!
Do I need these?
Thanks!
Sorry.
Do I need these?
Thanks!
Do I need these?
Thanks!
I have no experience with the other two brands. AFAIK the true and honest OEM manufacturer for these coils is a Japanese company called Diamond. If I were to shell out big bucks for coils I would lean towards the manufacturer that originally made them for Jaguar. They seem to last around 100K, which is fine by me, nothing made by human hands lasts forever.
Hello guys, the coil connector pigtails are available from the Motorcraft connector catalogue. These are the 2014 part numbers:
For the ignition coils:
For the MAF:
For the inertia or fuel cutof switch :
I have a AJ16 powered XJS and have had to replace these connectors in my car. Obviously we use the same coils, MAF , etc. Currently I am trying to figure out what connector works for the CTS from the catalogue. I did not build a whole harness, but have been thinking about it for a long time. The only problem with Motorcraft connectors for the coils is that the wires are too thick, so if you want to build a whole harness you would have to find some thin high voltage wires like the originals
Here is the connector catalogue. Most of the AJ16 connectors are probably there :
http://www.fordservicecontent.com/pu...torcatalog.pdf
For the MAF:
The following 3 users liked this post by Spikepaga:
For the ignition coils. Those thin wires are not standard wiring harness wire AFAIK. I am under the impression they are a type of thin high voltage wire . Am I wrong? Because that's the main reason I have been reluctant to create an entire coil harness out of standard wiring
Received 10,757 Likes
MountainMan (12-08-2014)
Rock Auto seems to have the Motorcraft part for the ignition coils, but it's labeled as a power window connector MOTORCRAFT Part # WPT1210
Spikepaga (12-09-2014)
For the MAF:
For the MAF:
My pleasure . I have been meaning to post it because the first AJ16 cars- XJS or X300 are about to hit 20 and harnesses are in all of our futures to some degree.
Now I am trying to figure out from that catalogue what the connectors are for the CTS, and the fuel injectors, which the XJS and X300 also share
I just had a new harness installed, after my XJR STILL had intermittent rough running and various codes after many other issues were dealt with. My independent Jag mechanic ordered a factory wire harness from England, for $750, plus a whole lot of labour because of the supercharger. Sigh. But it's now running right, strong, and smooth.
I hope for everyone else that an aftermarket connector/wire combo can be made up instead of what I had to pay.
