If timing chain breaks = bent valves ?
I am about to go look at a 1996 XJ6 VdP and the previous owner claims the lower timing chain has broken. He says he pulled the cam cover, turned the engine over with a socket on the crank and the cams did not move with the crank.
If this is indeed true, is the AJ16 engine an interference engine or not? I.E. if a timing chain breaks while the engine is running even at idle, will the pistons hit the valves? I have searched here and so far I have not found any posts that mention any broken timing chain issues. Lots of posts about noisy timing chains due to tensioner or guide problems but nothing about actual broken chains. Thanks in advance -- Steve |
I believe it is an interference engine. But there is never any interference. Let's ask Bob if he's ever seen an AJ16 with a broken chain. Bob?
If this has happened on the car you are going to see, we want to know about it please. I'd assume it would be a parts car then. |
I do not understand what you mean by "it is an interference engine. But there is never any interference."
Can you please explain this? Thanks -- Steve |
By interference is when the valve timing is so far off one of the valves may be down as the piston comes up and they hit each other causing much damage
This while the valve is fully intact and not broken but the impact results it proceeds to be and gets worse from there OH BOY DOES IT GET WORSE Some pistons have Scallop. cuts on the top of the piston to prevent this in design https://cimg1.ibsrv.net/gimg/www.jag...007175ad31.jpg |
Originally Posted by JensenHealey
(Post 2003380)
Yes, I do completely understand what an interference engine is and I am familiar with valve pockets in pistons.
I was just confused by the "there is never any interference" statement. What I find strange is the seller claims there is only 70K miles on the car. I don't know how a timing chain would break on a motor with only 70K unless some really strange condition occurred. In theory he is supposed to let me look at the car today so I guess I will find out, He says he had started to take the motor apart by removing the cam cover, radiator and etc but had to stop due to medical conditions that prevented him from doing further work. |
4 Attachment(s)
The owner may have been confused with valve chain rattle before the tensioner takes up the slack with oil pressure
There is a TSB on a revised tensionor and there is a oil viscosity recommendation http://www.jagrepair.com/images/TSB/...er%20Start.pdf :icon_dance-disco: Could be the original tensoner is bound up with oil tarnish and can be freed up with some oil treatment like Rislone that frees up old school hydraulic expanding lifters on ford engines that have lifter rod coming up from the internal cams before they designed them to place the cams overhead has worked for me on other old school engines You can buy a bottle at the local parts store and put it in during test drive and let it work things loose over time Broken oil pump ? To see if the timing chain is a tooth off , pull the valve cover and look for the flats on the cam shaft toward the front gear and as your rotate the engine around to the timing mark with a 34 mm socket ( 34 works but it may even be a 33 mm ) on the crankshaft nut No special tool needed , just your eyeballs If you dontt have a 34 mm socket you can remove the plugs to releave compression and with gloves spin a pulley around to your point of interest The timing mark on the crankshaft pulley should be noted in the TSB on the PDF or this new engine DPF below : # 1 cylinder at top dead center is the timing mark , see page 26 of pdf below Editing complete and good luck with your inspection |
The seller already disassembled the car so no test driving is now possible.
The rad, cooling fans and other pits are all in the trunk of the car. https://cimg6.ibsrv.net/gimg/www.jag...feb56bebdf.jpg https://cimg9.ibsrv.net/gimg/www.jag...5e922bfd5e.jpg Removed parts in trunk Cam cover removed |
Quote: "I am about to go look at a 1996 XJ6 VdP and the previous owner claims the lower timing chain has broken. He says he pulled the cam cover, turned the engine over with a socket on the crank and the cams did not move with the crank".
If the above is true then something is broken as the cams should rotate as the crank is rotated. This statement would not apply in that case: Quote : "To see if the timing chain is a tooth off , pull the valve cover and look for the flats on the cam shaft toward the front gear and as your rotate the engine around to the timing mark with a 34 mm socket ( 34 works but it may even be a 33 mm ) on the crankshaft nut". |
Talk about price negotiating leverage !!!!!
I got mine for $ 1,300 Depending on the other factors on the car condition in it's condition you can remove the front casting and see if maybe a D clip sheared on the chain sprockets You can bring the alignment flats on the cams and see if they line up Protect the cam lobes as they rust easily when exposed Put the engine back together and crank it up There is a special tool to putting the harmonic balancer on but some have just bull dogged it but is important to torque the nut to a very high value A replacement AJ16 engine runs about $ 500 as a worse case scenario Still need a determination of weither it is a interference engine and the ultimate thing would be to pull the head There is a TBS on using the head bolts twice and a stamp on the bolt head indicating it's been done , if followed In practice I don't know if it's a good idea as they stretch but it gives you information now and can be replaced later http://www.jagrepair.com/images/TSB/...ad%20Bolts.pdf :icon_dance-disco: There is a overheated AJ16 engine in Kansas City that is a candidate to pull certain parts off the core engine Some people would know more then me on this matter like Motorcarman |
The seller and I agreed on a price of $525 but I have to haul the car from northern New Jersey back to Youngstown Ohio
Good luck with it! Definitely worth the $525 in my opinion. I picked up mine for $400 as a non runner but it was all in one piece aside from the glove box.
You can most likely find a parts car within 100 miles of your home for that same price. Not worth hauling that hulk cross country. Why did he disassemble it? The whole story about the timing chain seems like blowing smoke. If the cams didn't turn when he turned the crankshaft, he would have had interference and the crankshaft would not have been able to turn anymore. Nevertheless, seems like that car will never run again so I hope you didn't intend to try.
Originally Posted by SleekJag12
(Post 2004335)
