Instrument Cluster Light not T4
SO I am replacing the bulbs in my cluster. A few threads he talk about T3 and T4. I used those in my Clock and temp display but they are too small to fit in the Instrument cluster. I also saw 8.7 was also used. Any help out there.
Without seeing it they may be grain of rice or grain of wheat bulbs in the below pic :
https://cimg2.ibsrv.net/gimg/www.jag...2a2da2989a.gif Dimentions are on this link : They come in 5 volts so be sure you get 12 volt when ordering . Penty on Ebay http://www.elfminiatures.co.uk/12v+B...0RkalZIWnZKSGM |
https://cimg3.ibsrv.net/gimg/www.jag...8d58d6acbe.jpg
https://cimg4.ibsrv.net/gimg/www.jag...e6224c72e2.jpg https://cimg5.ibsrv.net/gimg/www.jag...3359113653.jpg The cluster that pulled off the parts car that I bought has twist on for all the lights that is why I am confused. Am I missing something. Trying to do an LED upgrade |
Went ahead and ordered D8.3 LED lights. We will see if that works
Hello
On my 1997 XJ6 there were originally two versions of bulbs: > 24 off JLM28 (orange); and > 8 off JLM29 (white). The JLM29 has now been replaced by the JLM28 (i.e. 32 orange based bulbs). I have replaced these using the Ring autobulb number: R509TWGY These are 12V / 1.2W and sold in packs of 10. I suggest you DO NOT use a incandescent bulb in your clock. They emit too much heat and will melt the connection of the ribbon cable to the board. AKSpeedo (akspeedo.com) offers replacement LEDs. |
Thanks for the response but I am looking for the LED replacement
Hello
LEDs are definitely the way to go, if possible. Please post if they fit and are dimmable. Thanks. Regards Richard |
B8.7D from memory for the 8 illumination ones (the white ones in the picture), I got some from here in June 2016 and they still all work
And yes, the dimming works. https://www.superbrightleds.com/more.../attributes/14 |
Received my lights and they do not fit so sending them back. I sent them a message that they don't and told them that I would send them a light so they can figure out a replacement. Waiting to here back from them
So I sent superbrightleds pictures and dimensions of the bulb for the cluster. They are telling me that they are this one https://www.superbrightleds.com/more.../attributes/27
I have to send all the other bulbs back and reorder when they get them. I will follow up with if this is the correct bulb or not. |
Please let me know...I ordered B8.3D in the past and it did not fit. The bulb holder and the hole were the exact same size, so I could not get it to fit.
It is the B8.7D. I tried to go through the customer service sent them pictures and measurements and everything they needed to send me the correct one and did not work so I ordered every possible light that could fit and the B8.7D was the only one that worked. What is nice is if I ever can't figure another one out I have plenty to try.
