Interior lights not working after headlining changed
Ok guys, finally managed to replace the headlining, had the rear window removed and tinted, while it was out changed the headlining. Blew the fuse for the interior lights, curtsey lights map lights and visor lights. replaced the fuse in the R/H side fuse box but still nothing. Anything else to look for or do?.
Anyone???
Did you remember to plug the overhead console back in?
Maybe search the electrical diagrams to see if another fuse is related? |
You mean the one under the rear seat? That's what blew in my car when I did the headlining. Spent two days swearing before I realised I was looking on the wrong side. On a UK car it's driver's side.<br />
<br /> If that fuse has power and the connectors do not then you need to start chasing wires. But if all the lights have gone I'm pretty sure the fuse is the problem. The visor lamps, iirc, are ignition, fuse, switch, bulb, ground. It must be one of them at fault! |
